Utopiapga
I am ready to pull out the last bit of hair I have left!:angry:
Got the list done ready to roll and I go out down the road and damn thing is slipping slightly still under hard throttle. So back to the garage I go and try to adjust it up a bit. Long story short after a few trial and errors I slam the freakin ramp assembly shut!!!:bang:
So now off comes the exhaust then into the ramp assembly. Sure enough slammed shut. Got it loose then put it back together and tried to adjust it up again. Better but still not right!:loony:
No matter what I do just not right!
So now I notice cable just not right on lever. So I take it apart to so to make sure that is right. Find out the clamp has the little set screw gone and cable has slid out of clamp. So I go on a search for a little ass set screw!:loony: Of course can't find one so I go to work and tap out a little bigger hole and find one that will work at work.
So think I am good to go now!
Wrong, get home put everything back together and try to adjust it up then BAM!
The freakin ball and ramp assembly slams shut again on me!!!!!!!!!:bang::bang::bang::bang::bang:
I am on my last straw with this thought I had it when I changed the pressure plate and the clutch hub nut. I have NEVER had this much trouble trying to adjust a freakin clutch. :angry::angry::angry::angry::angry::angry::angry:
So now I notice cable just not right on lever. So I take it apart to so to make sure that is right. Find out the clamp has the little set screw gone and cable has slid out of clamp. So I go on a search for a little ass set screw!:loony: Of course can't find one so I go to work and tap out a little bigger hole and find one that will work at work.So think I am good to go now!
Wrong, get home put everything back together and try to adjust it up then BAM!I am on my last straw with this thought I had it when I changed the pressure plate and the clutch hub nut. I have NEVER had this much trouble trying to adjust a freakin clutch. :angry::angry::angry::angry::angry::angry::angry:
