serious help
rdavisfla
I have a 05 bulldog.. today I went to put on the brake and the horn sounded the flashers came on and the bike stopped running ..wth happened please help if you know
rdavisfla
ok..i put in a new battery and it still does it when I apply the brakes..horn blows flashers go on and it stalls
rdavisfla
I can start it and it will run for a few mins and I can keep hitting the brake a bunch of times but then after I hit it again it starts the bullshit again..
DRBarnhart
Insert title here...
I'd be checking for a short to ground in the brake light wires from the EHC (brown wire at pin A-2 and violet wire at pin A-9) to the lights themselves. A shorted power wire could very well kick the protection circuit in the EHC and cause the troubles you're having.
Dennis
rdavisfla
according to your helpful diagram its the left rear turn ...which makes sense that's the one that was replaced by a local Harley shop..if the reason its on is because of a short due to me being electrically challenged
