BIG VIBRATION
nobbyjohn
Is this what it feels like when your clutch hub nut starts to come off . I can't think of what else it might be , any ideas? I'am getting a bad vbibration on acceleration in all the gears , had to leave the bike at street vibrations in Nevada .
nobbyjohn
Yea some strange noise's, checked the bolts there tight.got the bike on the trailer and halfway home what do I check first.
pknowles
RETIRED
which bike has the problem
nobbyjohn
My k9 the one that juts had the trans rebuilt. And where do you find the high strength high heat red loc tite . Tried the Harley dealer they don't have it .
bigdogtech01
How did clutch feel? If it's nut, usually you will start to feel it at lever, along with the clutch will start to slip.
-It's possible the pulley nut is loose.
-Transmission mounting bolts themselves are loose.
-Motor mount bolts are loose.
-Drive belt is too loose.
-Primary chain is too loose.
nobbyjohn
Clutch feels good belt is adjusted could only get to a couple of trans bolts but they were tight . Should be home in about one hour will pull primary cover hope there isn't to much damage Ihave more money in this bike then I have miles !!!!!!!!
Macdwn
I had that prob a couple years back and it ended up being the primary tensioner fell out. New bolt, nut and some red loktite and it was good to go.
nobbyjohn
Clutch hub nut backed off,it made the adjustment on the chain loose so it chewed up some of the inside of the primary cover.hope that is the extent of damage,where can I get that new heat treated nut that was mentioned earlier I think maybe baker is making them?
bigdogtech01
I can send you one if I have one..I'll check tomorrow. Otherwise, I need to order other parts from Baker anyhow, so let me know if you want one. They are $9.
