2003 Service Manual
GrapeDog
Gotcha. Thanks for the manuals info, and the advice.
That's kind of a trick question. I have the following pdf shop manuals that I occasionally look thru for information:
99-01 Indian
97-98 Harley Soft tail
00-05 Harley Soft tail
For an 03 BD, what might easily translate back and forth would be info for brakes (bleeding, dis-assembly and re-assembly, wear info),
some suspension (shocks, fork similarities), nuts & bolts, tires...pretty much everything except engine & electrical. Reading thru them
does give you AN IDEA of how things work or are put together but probably would not be good to use in a SPECIFIC area of concern.
There is a wealth of info on this forum, 'SEARCH" is your best friend.
Print it out, study it and ask questions - it will get you over any "bump" you may run into.
AllanInman
Took care of the Intro tonight! Downloaded the Vintage Manual that another member had a link to but not sure it applies!
Thanks!!!
C00lHandLuke
Franco sent me the manual, and I am very appreciative of that, but the chapter on Electrical is corrupted. He stated that is the way he received it but that someone on here might have a copy of the chapter. If anyone on here has a uncorrupted" copy of the chapter covering electrical I would really appreciate it. My email is jsb0671@yahoo.com
Thanks in advance.
