LA_Dog
Go Fast, Go Faster
Hi all- Need some expert help!
So I just got this bike and have been going through it front to back- it has a new 21" wheel on it, and looking closely it appears like there should be a spacer on the throttle side of wheel.
Here are some close up pics- anyone know?? there is no play in the wheel and it seems to turn freely besides some friction against the outer brake pad, the brake rotor is sitting slightly right of center (towrds outside) in the caliper (looking from front of bike).
The brake side of wheel has a spacer and it seems to sit inside the wheel bearing a bit. On the throttle side, there is a thin metal sleeve protruding about 1/8" from the bearing, and no spacer.
The axle diameter seems to measure 22.09 mm (0.89 in).
