Although my Pit is an outstanding breed here are a couple of things that I ran into along the way in ownership that I would like to see:
Functional
- Better Speedo all the way around, too much discussions on speedo issues with flashing mods
- Drain plugs on all lube areas (primary, tranny, oil tank) those pipe threads are a bitch.
- Handlebar control areas to polich around the buttons, Chrome them or make buttons more flush, my mothers mag is eating up the buttons
- Gas gauge, not to detract from the tank if possible but is a hassle if I show off at the station and forget to reset.
- Keyless start, Harley has a good idea on the switch turn and I know BDM used to allow for key removal that made problems with keys falling out but the key insert could be adjusted to make it look more clean.
Beauty
- Stock internal weights on tires to eliminate unsightly external balance weights, not sure you can do this out of the factory but would be nice
- More diamond cut/polished stacks on the engine
- Rear LED brake light band under the rear fender, saw a chop installed with this and in addition to normal lights it lights up the rear tire when the brake light is engaged, awesome. Not sure it is legal though.
- Color schemed spark plug wires. Eliminate any black wiring from the bike if possible, unless it is a black bike.
- Stock air cleaner vents, the vented look was a first cheap mod that I did that just increased the meanness of the engine.
The fit and finish is still in my mind second to none, really it is the small pieces that I have found easily moded that makes the bike perfect.
JP
