Carb puking oil
Need help on with my carb. The other day I take the sled out for a short ride come home and gas is spewing out of the drain hose on the carb. So I remove the carb and decide to clean the carb and bowl. The bowl was clogged up with crud. Put the carb back together and go for a ride. Now I am back to having oil (no gas) spew out all over the bike. Looks to be coming from part of the air filter (spike) and from the bottom of the carb (screw). I know some people use the puke cans but it doesn't appear to be coming from the drain hose. Any suggestions on the fix? will get some pics soon.
Letbigdogintocanada
Have u recently changed the oil?i had that's same problem ,where it was coming out through the filter and breather hose,so now I put a bit less than recommended and don't have that issue any longer.
No I haven't but plan on doing a oil change this week due to the bike sitting for 6 months without being started. BTW it was leaking before sitting in the garage. I will let you know once I complete the oil change
thanks for helping
Jersey Big Mike
100K mile club
The other thing that will create this problem is using a twin cam filter -- it fits but the evo can't deal with it. MAkes it puke oil insanely (had this happen on my 02 rev tech on my BMC)
It puked so much oil that it was smokin on the pipes and I had to have it towed in.
There was a fix out there -- called Cure Vent Plus -- made by direct Parts -- I actually bought one and never got around to installing it. I don't see a current source but I only did a fast search.
