FRAME HAS A CRACK...advice wanted
hayseed
IMHO,,, if you have the frame fixed the way it should be done as described above,, the cost will be more than half the cost of a new frame and you will never have to worry... I would spend the extra on a new frame
bearman
Who says that a new frame will not crack in the same place? We would all like to think it wouldn't, but you can't be certain.
The main thing to consider on this frame repair is what the parent metal is that the frame is made of. It may be chrome-moly or it might be just what is called mild steel. You could contact Daytec again to be sure. The welder will need to know what kind of filler rod to use and the material will determine if he needs to pre-heat or post-heat treat the weld.
I can’t see the pics from here at work but if the crack was at a weld, then it was probably caused by that weld not being done correctly in the first place and creating a weak point. It may have been undercut or not enough penetration. It may have been internal rust.
The way that Kapt. Describes is a foolproof way to repair any frame damage. But a good pipe welder can weld two hollow pipes together without anything on the inside and make the weld stronger than the surrounding pipe, they can even get a “bead” on the inside so that the outside can be ground flush, and still be stronger than the pipe. And you don’t need high frequency, all you need is a DC (direct current) machine. I’ve seen it done with an inverter welding machine (Miller Maxstar 150)) that was about as big as a lunchbox and plugs into a 110 outlet, and a gas bottle.
Knuckles
The initial estimate to cut the frame, slug it, split the cutout and weld it all up, was $200. Shop has the bike since late yesterday and hoping to work on it Wednesday. New frame was approx. $1,400.
bearman
.......I can’t see the pics from here at work but if the crack was at a weld, then it was probably caused by that weld not being done correctly in the first place and creating a weak point. It may have been undercut or not enough penetration. It may have been internal rust.....
I finally got around to looking at this at home. I am not a certified welding inspector, but I would bet big money that that crack was caused by a bad weld. I am sure of it. The crack goes right down between two weld beads.
But I am sure your welder already pointed this out after he saw it.
So any updates?
Knuckles
yes all welded up and painted
bike still not back together( trans and starter rebuild)
my dad had some health issues and no time to get it back together
haven't ridden since early September... driving be crazy
I'll post pics one day off the weld
zenBD
Glad to hear it worked out! :cheers:
