wolfen
I went to adjust the clutch which I have done thousand times on a Harley. This is the first time I`m attempting it on the big dog. I couldn`t get into neutral when I was at a stop. When I put into 1st. gear it would lunge a little. So I figured I would adjust the clutch. I read the how to and even have a manual. I can`t get the ball & Ramp back in right. I`ve been able to get it where there is a little pull after I take up the slack in the cable ,but , doesn`t seam to be working right. I`ve taken it a part 6 times now. Trying to get the ball & ramp to stay in place , but , with no luck , it seams to always return to the same place which is where it suppose to be when you pull the clutch. What am I doing wrong? Is there some easer way to do this? It`s the first time I`ve worked on a right side drive. It`s a 2005 Big Dog Chopper. If anyone has any advise I would appreciate it.
Thanks
Thanks
