francoblay1
The Spaniard
I have not seen SVEN here for awhile.... SVEN, your input please?
I´m NOT joking.
I´m NOT joking.
He will compare the Sucking and blowing with his childhood or something of that nature. LolI have not seen SVEN here for awhile.... SVEN, your input please?
I´m NOT joking.
:roll::roll::roll: he he he... I still remember that thread where you two had a good "exchange" of opinions. lolHe will compare the Sucking and blowing with his childhood or something of that nature. Lol
I hope to see you in a couple weeks Dragan![]()
Your EHC is performing correctly. Rule that out. As others have said check your ignition moduleI looked at the EHC and when I switched on the power there was a yellow led and a green led lightning up. After I tried to start there was a red led blinking as well.
X2:2thumbs:His bike has lost compression on both Cylinders at same time, as well as blowing out of the intake rather than sucking...this is cause from failure on the Pinion side of the motor. It's very possible the Pinion gear key failed and threw it out of time, or the pinion shaft itself.
He was riding it down the road and it just stalled. He then could not get it to start again. Yes it's a big job, but hopefully for his sake, not a lot of $$.X2:2thumbs:
That sound about right, but the lack of compression or starting has me thinking that it should have fired and then failed. Happened on a mates HD last year, he had an S&S 124, stripped the the keyway in the shaft, big job lots of $.
Absolutely Dragan!!Hi everyone,
just want to update you on my K9. The piston gear nut got loose so the piston gear key failed or broke and threw it out of time and also damaged the crank shaft and the push rods. :bang::angry::bang:
Now it´s going to be lots of $$$$$$$$$.
I really want to thank Andrew for his support and time regarding helping me out finding the problem. You´re the best! :up:
Hopefully we´ll find a way to work this out and I´m really looking forward meeting up with you in Sweden.
We really need to document your first European trip on the forum with a lot of pictures.
