wont fire
Big dawg
Turns over power to coil no spark all lights work red light on thunderheart module red when powered off switch. Blinks when starting fuel in exhaust plug wires all real clean no corrosion power to the coil none to the plug looked at all connectors unplugged replugged. Worked until changed all fluids ran once up down the street turned off put away 1 week lat:aer turns over doesnt start ..
DRBarnhart
Insert title here...
... power to coil no spark ... red light on thunderheart module red when powered off switch. Blinks when starting ... power to the coil none to the plug ...
If all this is true you may want to check the yellow wire that goes from the ignition module to the coil for connections and continuity since that's the one responsible for telling the coil to make the spark.
Dennis
Slider
Dennis
That's where I'd start too
