Tdubb
OK Andrew I think I'm going to tackle this myself. Just a few questions.It's not a bad job if you have all the tools..the pulley nut is LEFT hand thread, so clockwise to loosen, and it's 1 7/8", might be able to find that socket at Autozone or someplace like that.
-Remove exhaust
-remove clutch pushrod cover off pulley cover.
-remove clutch pushrod (DO NOT move your clutch lever while this is apart)
-remove pulley cover.
-remove pulley nut (probably have to use an air impact, unless it's loose)
-remove drive pulley.
-remove pulley spacer from within leaking main seal.
-use seal puller to remove main seal (note small O-ring/quad seal under pulley spacer)
--All seals can be purchased from an H-D dealer using mid '90's to early 2000 5 spd H-D's, such as FLT's, FLST, FXST
--While you have it apart, check for any end play, in and out, up and down...if play exists, then you might need transmission bearings.
--Also check condition of pulley itself while apart...inner splines for wear.
1. The clutch pushrod cover removal - does it just pry off? How easily? A little worried about denting or scratching the pulley cover.
2. The service manual says to "fully collapse the clutch adjuster cable" before I remove the clutch pushrod cover. You're saying to skip that step correct? So I don't need to adjust my clutch later?
3. When pulling the clutch pushrod it looks like on the end there is a wiper seal. Will that stay on during the removal of the pushrod? Looks like I would wand to pull the pulley cover and pushrod at the same time by looking at the exploded drawing (64)
4. Do I need the baker pulley locking kit to remove the pulley nut?
5. You say to remove the spacer within the seal. Is it pressed in or will it come out easily?
6. Is the o-ring and quad seal one unit? Do I buy it as one unit? If not, replace both?
7. Finally, should I replace the exhaust gaskets?
