bigdogtech01
Not sure if anyone has posted pics of the Old Main shaft vs. the Newer in the DSSC 6 spd Right side drive Transmissions....if so, then my apologies
Otherwise, here are some pictures of what to look for to determine what is old and what is new. To start with, these shafts were produced from late 2004- to early 2006 transmissions. You can do an easy check by looking at the right side of the transmission, top of the case. There will be a set letters and numbers, reading from left to right.
-The first letters stand for the Baker part Number... Ex( AA )
-The second letter stands for a revision... Ex ( G )
-The first Number stands for the year produced... Ex ( 08 )
-The third set of numbers will be the day it's built... Ex (186)
-The last numbers are the Daily Build sequence...Ex ( 5 )
So a transmission with number AAG0818605, was built on the 186th day of 2008.
If it has an 04, 05 or early in the year 06, it most likely will need the updated shaft.
To verify if it does need one (unless you know for a fact it has already been replaced and updated) you can look at the end of the Main shaft ( Input side ) inside the primary.
Here are some pictures to help show what to look for.
This picture shows new M/S on the LEFT, and old M/S on the RIGHT...Notice how the new (Left) has threads that go all the way up to the splines, with no gap. The Old ( Right) has a small gap so because of this, the threads are not cut all the way up to the splines
If you happen to have the shaft out, the Newer M/S will show this part number
The OLD M/S will show this part number
