HEEEEELLLLLLPPPPPP!
txcrod6
Well it sounded easy enough....I was taking off the bowl so that I could see what intermediate jet was on there n see what size I needed to go up to. Then I pull off the bowl n hear something hit the ground. Now I have a small spring n two small ball bearings that I have the slightest idea where they go. PLEASE tell me someone can tell me where they go so I won't have to be without my bike......:bang::bang::bang::bang:
francoblay1
The Spaniard
arrrghhhh Carlos! did you open up the pump case??? you should not touch that part... no need to open that to drop the bowl.. only the 4 screws...
Check in this files attached. you might find what you done wrong.
CANOT attach, it is too big.... PM me your email address.
You open up the accelerator pump
Sent from my DROID RAZR using Tapatalk 2
txcrod6
thanks to franco sending me the S&S manual i found out what they were and where they went. i just hope that by putting them back in everything will be just fine.....any suggestions?
francoblay1
The Spaniard
Look at the bright side of it... now you know how the accel pump is from the inside! :D
You will be fine :2thumbs:
txcrod6
i didnt get to start it up yesterday because it was so late and i didnt wanna piss off the neighbors but it is all put back together with the new jets 72/29.5 and when i get home today i will start her up and see how she likes the different jets...
francoblay1
The Spaniard
What jets you had in b4? what elevation are you at? you are in lower scale as jetting goes...
txcrod6
the guy that i bought it from who lived in IL had 80/32...i live in Colorado Springs at an elevation of 6K+, w/ dual runner and santee LaFs...
txcrod6
Ok put everything back together turned it on n it sounded great until I smelled gas looked on the ground n saw a big puddle of gas. Looked to see where it was coming from n it was coming from the bottom of the overflow tube.....any suggestions????
RCAdd1ct
JAFO
Either the needle and seat are stuck, or the float is bound or got bent.
Either way it sounds like you will need to go back in.
