Clutch Travel Problems
DoubleD
First of all Hello everyone its been a long time since I have been on the site. Second Yes I Searched but just didn't really find a good answer. With that said here is my problem.
I have a 2008 Ridgeback. I installed a bandit clutch back in 2010. I have never been able to get it adjusted to what is should be. With all the slack removed form the clutch cable I can barely get .070 in movement. The bike still lurches when going from neutral to 1st. Also when I say removed all the slack I mean all of it. the clutch lever is snug to its housing and it takes the full range of motion to the grip to get the .070. If I take any more slack out it slips. I'm thinking maybe issues with the ball ratchet mechanism? Oh yeah installed a Barnett clutch cable at the same time as the clutch. I read a post on the forum that the 2008's have the easy pull clutch. My dealer wasn't so sure that is true. Could that be my issue? Should I replace the mechanism with the Non easy pull?
By the way for what its worth I received zilch of help from Bandit Machine. All they did was refer me to a shop. Well I don't use shops I do my own work. On another note James at Baker tried to help and gave some great suggestions. Well except for one " Have you checked with Bandit" LOL
Any thoughts, ideas or suggestions will be greatly appreciated.
Double D
claw
I have the same issue. I am at a dead end. I couldn't find a "pre-easy pull". I thought I did, but Baker sent me the exact same ball and ramp that I had in it. I'm considering having a machinist mill the ramps a little deeper, and then using slightly bigger balls. Thats the only solution I can come up with. Maybe someone else will chime in with a better idea.
bruce
you may no all of this, but here goes, you only need a little distance. when you pull the lever just enough so the pressure off so things release, so first I would take apart the ball and ram assem. and make sure things are OK there - regrease while you are in there ( i had problems there once,things were all there but not in proper places ), then I would start from scratch and adjust rod and then cable - you should have a little play at lever. If this does not work, you will need to look into shimming it properly
bigdogtech01
welcome back :cheers:
Yes, your 2008 has the "Easy Pull" ball and ramp. But, it sounds like you need to go back and just do a complete clutch adjustment.....DO NOT DO AS MANUAL TELLS YOU TO...or how you would adjust an H-D....here is how I do it and it works very well.....
>First, loosen pushrod jam nut.
>Then loosen your clutch cable all the way.
>Now go back down to pushrod and turn clockwise till it just bottoms out with light drag.
>Go back up to your clutch cable and tighten the adjuster all the way up till you have 0 (zero) play at lever while holding back on cable near housing.
>Now go back down to the pushrod and turn counterclockwise 1/4 turn and lock jam nut down.
>Go back up to clutch lever and make sure you have 1/16"-1/8" of free play while holding back on the cable near housing.
> If you have close to 1/8", lock the cable down, and you are done with your adjustment.
If this does not work, you might have to check the clutch itself to make sure it's setup the right way.
DoubleD
Interesting!! I have always followed the manual but had to do a little less than an 1/8 turn to achieve what I have now! I'm out of town till Monday. I will give this a shot then. Thanks for the advice hopefully it will make a difference. :up:
DoubleD
I had the same thoughts but have torn it down and checked it since I replaced the cable. Re-greased and reassembled.
Thanks!!!
boomer4444
ball n ramp
[/ATTACH]thought maybe this would help you as the bandit recommends not using the easy pull ball n ramp the easy pull is on the left, notice how long the grooves for the "balls" are,,less grooves,= more spread on the ramp= more push on the rod! doubled if you need other ramp let me know as i have a extra as you can see
claw
PM Sent
jjarkys
Double D
I have the early ramps and could only get .075 out of it with one shim. I also installed a new cable. John at bandit told me .055 is typical with the later ramps and he explicitly stated you can not use the later easy pull ramps. I believe .070 is min required.
jimizee028
TRUE COLORS COLLISION
I also am installing Bandit at this time and was specifically told to remove my easy pull ball and ramp and put the original back in.I was also told to use 1 shim...
Bowhunter
DoubleD, after you disassemble the ball and ramp and re-grease it, it is very easy to accidently put it back on incorrectly. While the ball and ramp is apart with the clutch cable given all the slack it has in the adjuster, pull the ramp assembly all the way rearward and make sure that as you reassemble the cover plate and then go to the tranny that you do NOT pull on the cable. If you do pull on the cable it will take all the play out of the ball and ramp assemby and there will be basically NO separation when you pull on the clutch cable. It is essential that the ramp be pulled towards the rear of the bike as much as possible while replacing the cover plate and then going to the transmission. As Andrew said, adjust the pushrod into contact FIRST before touching the cable. Good luck, hopefully this is your problem and it will be an easy fix after adjusting the clutch per Andrew's instructions.
V
I had the same issue on a 08 Ridgeback. Finally set it where the push rod just made contact with the bearing, then when I locked down the nut it pulled the rod back slightly. Had the cable tight all most zero freeplay and it still was a slam into first gear. Once the bike warmed up it improved quite a bit. Bandit also told me to run only 30 oz of fluid and this may have help some as well. When you drain the primary there is still fluid in the lower part of the front of the primary that doesn't come out. The only way to get it all out is to remove the cover
DD I also had the same situation that you did whit the warped basket/hub assembly. Ended up with a bent shift rod and 2 bent forks. Had 2 baker baskets do this before the switch over to the bandit.
With the 330 tire on hot asphalt, reved up and a good launch something had to give and with mine it was the Baker
bigdogtech01
Sounds like this Bandit clutch is more of a headache than it's worth...My question is...Why are people installing this clutch setup? For $50, I can make you a clutch spring to put into your stock BDM/Baker clutch that will give you at least a 20% increase in spring pressure. As long as you have the updated carrier, ($150 I believe) your clutch should be very reliable...and much easier to setup and maintain.
Just my 2 cents.
ItSounds Allot Like All The Squabble About EHC gremlins To Me
I Have The Bandit System And I Love It
Im running A 124 That's Putting Out 132 Hp And 138Ftlbs Of Torque And I Have Had 0 Issues With it
And That's With Me AT 300 Lbs And About 12000 Miles
And Anyone Can Ask RayWood. I Don't Baby This Thing
bigdogtech01
So you think it's just the way they are installing it that's giving them such a problem? I have yet to see one on any of my customers bikes. But it sounds like from what these guys are describing, it's a fine tune thing. Seems like they could build it so you just install it like you would with a Baker setup. All the Baker primarys are the same '05 and up...with the exception of the compensator addition on the 2009 models...so, why can't Bandit make a clutch that will bolt right in?
jjarkys
I don't think there are any issues with the clutch itself. DoubleD just needs to toss the easy pull ramps. Once you get the bandit setup properly, it works great. A lot better than stock ( at least in my situation). IMO
