First of all Hello everyone its been a long time since I have been on the site. Second Yes I Searched but just didn't really find a good answer. With that said here is my problem.
I have a 2008 Ridgeback. I installed a bandit clutch back in 2010. I have never been able to get it adjusted to what is should be. With all the slack removed form the clutch cable I can barely get .070 in movement. The bike still lurches when going from neutral to 1st. Also when I say removed all the slack I mean all of it. the clutch lever is snug to its housing and it takes the full range of motion to the grip to get the .070. If I take any more slack out it slips. I'm thinking maybe issues with the ball ratchet mechanism? Oh yeah installed a Barnett clutch cable at the same time as the clutch. I read a post on the forum that the 2008's have the easy pull clutch. My dealer wasn't so sure that is true. Could that be my issue? Should I replace the mechanism with the Non easy pull?
By the way for what its worth I received zilch of help from Bandit Machine. All they did was refer me to a shop. Well I don't use shops I do my own work. On another note James at Baker tried to help and gave some great suggestions. Well except for one " Have you checked with Bandit" LOL
Any thoughts, ideas or suggestions will be greatly appreciated.
Double D
Double D
