Returning it Saturday, if the unit is bad they'll replace it. If I installed it wrong they'll charge me for installation. Going from the instruction, I didn't install it wrong. It only required me to configure two wires. This was a no brainier compared to the Wireplus installation.What is your final outcome with this speedo problem?
I was more glad that it wasn't my doing and that there was something wrong with the Speedo. I don't want to be afraid of working on my own bike.Glad that they got you up and running... :2thumbs:
I knew I wasn't installing it wrongGlad it all worked out for you. Usually i have bad luck like that.
More like had me pissed!!:angry:But It HadYou wondering. Glad You Got It Fixed.
Setting mileage? Or Speed?Old thread I know... but any chance someone has the instructions for setting the mileage on the Medallion speedo?
Mileage... just installed and trying to set the odometer to show accurate mileage on it.Setting mileage? Or Speed?
Not happening....why would an OEM component allow for illegal tampering.Mileage... just installed and trying to set the odometer to show accurate mileage on it.
Different gauges... but use the same method (holding both buttons) and that didn't work.
Right... and I'm currently at 51 miles on the new odometer. Which is why I'm trying to find the instructions to do so, so I can set it and NOT be called out for tampering with it.Not happening....why would an OEM component allow for illegal tampering.
Even aftermarket speedometers only allow you to set mileage for a short period of time
Didn't know there was new ones still around. Who made it? I apologize I assumed you got a used oneRight... and I'm currently at 51 miles on the new odometer. Which is why I'm trying to find the instructions to do so, so I can set it and NOT be called out for tampering with it.
Bought it new from BDM back in January of '13... but only just installed it.Didn't know there was new ones still around. Who made it?
Thanks for looking. I sent a PM his way.I looked and can't find the instructions that I had for the medallion speedometer. I probably gave them to member Geoffmt when I sold him the bike.
