2008 Ridgeback - Brake Fluid? - DOT 5?
sheriffd2
Hi all, did my best to search before posting the query, but couldn't find a definitive answer...
I installed new controls (well, used, but new to me) on my 2008 Ridgeback, so obviously a brake bleed and Mast Cyl top-off are in order. I bought a bottle of NAPA DOT 5, but before going further I wanted to see if this is, in fact, the correct fluid type? THANKS!
be careful not to overfill the front res. it is so easy to do. keep it down about 1/8-3/16 below the lip and keep checking it. if you do overfill, open it up and put the tip of a paper towel in and let it absorb a little at a time until it gets to the correct level. if overfilled, it will weep out the breather/screw holes and make a mess.
Trainguy
Chromeoholic
There's some good advise right there:2thumbs:
There is a level line inside the reservoir
Sent from my DROID RAZR using Tapatalk 2
