06 k9 brake lights
Johns150
Ok new dog owner stupid question.
Is there a brake light switch in the front brake control. I only get brake lights with foot control.
Thanks john
yes, there is a little magnet inside the control that triggers the brake light. somebody else with more experience with it will tap in shortly.
bigdogtech01
Yes Correct. This switch can move if the small set screw is loose. This can cause the switch to not function properly giving you no brake light function at hand lever. However, foot pedal will still give you brake lights.
Another cause could be a bad switch or bad wire.
Pull the switch housing apart. You will find the small Allen set screw at the bottom just below the magnet switch. Loosen the set screw up and move the switch back and forth while watching your tail lights to see if the brake lights come on.
If you get the lights working properly, you want to set the switch before putting the housing back together. To do so, move the switch until the brake lights turn on, then back the switch back out till the lights turn back off. Move your lever to verify the brake lights are functioning correctly. But, don't have it so close that the brake lights turn on with very little lever movement. If set too close, they can possibly flash on and off from vibration while going down the road.
Once you get the switch set. Tighten set screw back up and install switch housing.
NOTE*** Do NOT over tighten set screw. It will damage the brake light switch.
JeffM
You will require a bloody fine allen key, and if your like me, you will need up close and personal glasses.
I gave up trying to adjust mine, i just dab the back brake if i am using the front BUT only if someone is behind me.
Johns150
Fixed
Omg that housing is a pain in the ass. It just needed to be adjusted. Next time I will use the rear for lights.
Thanks guys
Thanks guys
Haha it's not that friggen bad.
As Andrew stated...most likely someone took it apart and when they put it back together didn't get the switch close enough to the magnet to trigger the lights when pulled.
You should be able to see the magnet it sits inside the housing on the lever, it's a little black piece. I had pictures somewhere. You can try passing a magnet you have laying around through to ensure it's the positioning rather than the switch if you want to know what the issue is before tearing it down.
