The Rebirth of the Phoenix
LamboV12
Thanks Chris - My rotor looks nothing like that... very plain. Yours would go with my rims. I'll have to see what Nelson can come up with...
N8KAM
Hay Chris.... Just to let you know...... I will NOT Be riding on the right side of your bike.... :roll: :roll: Ever.... :roll: :roll:
Seriously.. Bike is looking awesome... looking forward to seeing it in person.. :2thumbs: John.
lee
I'd love to ride along side you some day - left side, right side, don't matter to me - that goes for all the rest of you too...well, nearly all!
Come on man... there aren't any baffles.. it will only hurt for a few mins... :D
N8KAM
It would be nice to see you getin on it at night....:2thumbs:
A little flame ?maybe roast a marshmallow.... or the paint off of the car next to you....:roll:
Hell yeah!!! :whoop:
Made some more progess today.. just have to finish up a couple things. Bleed the front brake, mount front fender. Then if the new headlight mount that is on there was chromed I would be DONE. But that will come off and be sent out for chrome monday.
Well boys n girls... if it wasn't for needing the new headlight mount and starting it... I'd be done done done!!
So here's the final break down...
The headlight mount that came with it. Didn't like the way it pushed the headlight out way past the forks and the double joint wasn't stable in my opinion.
So my bud Al and I designed a new one and machining master Steve cut it out
Some slight mod to the cut to allow the light to swivel down more.
Mount it up. don't mind the long bad bolt... just for mock up
BAM
Lights up well too
Low beam has a nice wide spread
Hi beam is high and tight
Also got the front wheel hub back from Steve and mounted that up with the crush axle spacer
Mount the rotor on
Then throw it on the forks, and mount up the caliper with some small shims to center on rotor.
Mucho better on the clearance
Hung the brake line with clamps
Pulled the tank to mount the speedo and tidy up the wiring
Put the tank back on with the wires all tidied up and things like the clutch cable and throttle cable stays in place
Assembled my passenger pegs with the newly chromed clevises and new roulette pegs
Decided to set those aside for now...
Strapped the front wheel in place so it wouldn't fall to the side and spill brake fluid all over from the resv.
Bled the brakes which being completely dry ended up being a ROYAL PAIN!!!
Then cleaned up the place a bit. No table is a good thing.
Then hung the front fender in place
What do you know... she's in like Flint!!!
With the brakes working, we put her back on the rubber, cleared the bubble wrap from under her and got to try out the new kickstand. Looks like it will work GREAT!! Real solid feel when you lean it. No more wobble out when you lean it over! Plus the lean angle seems to be JUST RIGHT!
Put the condor back on, wheeled forward...
And that's how we do it SON!
At the end of the project I ended up with all these empty zip locks that I used to sort the pieces. Used a helper beer bottle to show you just how many were used
Got rid of the table and the garage is returning to normal...
Got a contractor using the garage Monday morning for a home improvent project, so slide the sporty over and cover them both up... till next weekend when we fire it up like a un-vailing.
My utmost gratitude to Alhall, Cavracer (steve), Vickie, Nelson, Chopper Dave, Big House, Eric (Choppin Steel), Jake (lowdownchopshop), boys at Full Throttle, Exotic Coatings, Browns, and everybody here that has helped out in any way. Without the support of these people this would not have been possible.
Last and definately not least... my wife. For all the countless hours I spent in the garage, her car being outside all winter, me being in a bad mood for whatever, and supporting me as a good wife does. You're simply the best!
Cutter
:2thumbs: To Gas and everyone else :2thumbs:
CCRainman
Gas, I see your controls are still billet in the pic. What are you waiting for, everythig else is chromed? Looking good dude!
didn't want to bother with that... had other projects going on with those... if that is all I have to polish that's ok.
txchopperguy
Gas,
Maybe in your video "The Unveiling of the Phoenix" you could include some shots of those "three girls a giggling"...from the calendar thread post...lol
