Twisted vs Ultima and Taylor
Letbigdogintocanada
Hey,Just trying to figure out if i should go with Twisted or Ultima wiresTwisted are advertised at 40 ohms per foot,and ultima at 300.Not really sure what the bottom line is after reading a bunch of threads on the twisted.Does any one know what ohms were on the factory wires?any feedback would be cool,thanx:up:
wyatt580
got magnacore myself they'll make you custom for same price as stock just lookem up...very happy and look good....just my 2c
Little-Boo
I you are interested in the Twisted I have a Black and a Yellow Set that I never used, I didn't like the the look :loony:. You can have them both for $50.00
Carlos
Iman
I have the Taylor Thundervolt 8.2 Bought them thru Sumax - you can have them custom cut to length and they have a bunch of different colors to choose from
rasdes
I had TACH issues with the initial set of Twisted Wires, returned them and discussed the issue w/Andy at Crowe Cycles. They made a special set supposedly with 2500 OHMS, no issues with the TACH since I installed them about a month ago.
ChoppaNoob
I disected one of the Twisted wires and found that there was a 7mm prowire inside. The outer thicker colored part is just cosmetic.
Iman
Adam---don't have a part number but if you go on sumax.com you can look up spark plugs, they have 4 or 5 different kinds. i got the thundervolt 8.2 but they also have 10. i run with dual coils so i need a 90 degree spark plug boot and a 180 degree coil boot.
Letbigdogintocanada
:2thumbs:
Thanx for your feedback guys,I appreciate the info:2thumbs::cheers:
rasdes
Adam,
Have no idea, , Andy (Crowe Cycles) said they'd have to make a special set and increase the OHMs; when I received the box 2500 was written on the outside, said he's had to do this for other Big Dogs. I guess some work with the standard 40 OHMs and some don't. It's cold here but I did take it out for +/- 50 miles on Friday, all seemed OK, no fluctuation of the TACH.
Nukeranger
Nukeranger
I agree with the statement "If they work, they work". If they don't, try another set in my opinion. There is always a bad apple in the batch!
