Call your local welding supply house. NOT HOME DEPOT! You are going to have to rent a bottle of gas from them. They always love new customers and will gladly come deliver the bottle and spend an hr or 2 to get you started. I am a certified welder. If you can braze with OXY/ACD then you can tig. Basically the same princible as far as technic. push down on your foot control making your tig torch handle HOT. Then puddle up your metel till it is a liquid pool then start making small circles. use your brazing rod to add metel when needed. If your torch is blowing through instead of puddling up, turn your heat down on your machine. If it is popping turn up the juice. The brazing rod is just that, a rod to lay more metel into the puddle and work it. It is actually quite easy once you get the hand foot cordination down. That is the hardest hurdle to jump over. I can teach a guy in my machine shop to tig weld in about twice the time it takes me to teach them to mig weld. Oh ya, do this 1st. Get a 1/4'' sheet of steel 12'' long x 12'' wide. Practice starting from left to right. Creating a puddle and making a small circle then easing to the right while still making a circle. (DO NOT MESS WITH A BRAZING ROD FOR NOW) when you reach the right side of the plate, it should have taken you 5-6 minutes. Now go back to the left side drop down 1/4'' and do another. When the plate is full turn it over. NOW, do the 1st line the same as you did on the 1st side. Now for the second line start your puddle and start your circles bringing them 1/2 way up the first line so you are doing a 50% overlap. Once you have done this and the 2nd side is full, flip the plate back over and go in between your lines 1 and 2. NOW GET YOUR BRAZING RODS OUT, puddle up and slightly bring in the brazing rod. metel will melt off, now while making your circles start filling in the gap between the 1st and 2nd lines with the brazinf rod. when the plate is full PM me.
