Part number?
wolfen
Hey everyone,
I have a 2005 Big Dog Chopper. The front lower on the front end ,the right hand side when sitting on the bike. The one with the pinch bolts. What is that called? Do you guys have any idea what the part number is? I have to buy a new on , because one of the pinch bolts broke, I tried to get it out ,but,was not successful. I probibly should have taken it to a machine shop,but,since I have removed many bolts I though I could get it out. Well I was wrong . So if you can help ,then I will probibly order from that BDM parts place. Unless someone has a better suggestion.
Thanks
wolfen
How much would that cost? I don`t know if it would be worth it. Now I have scratched the chrome and fucked it up some. So I think it would be best to just buy a new one. If I only knew what the BDM parts place called it or knew the part number. If that doesn`t work I will ship it to you so you can do what you can with it.
Thanks
OR you could use this as an excuse that you need a springer front end.:2thumbs::2thumbs::2thumbs::cheers::cheers:
I should be able to fix threads for $50.
I bore the hole on my mill.
I use a locking Stainless thread insert so you won't have to worry about it breaking again.
Unless you over torc it or use to much red loctite then you might have problems again.
Strip and rechrome is going to run around $150.00
Shipping will be around $20
Were here for you if you need us.
Done a few of these already with great results.
phatchopper300
I just wanta ride
Done a few of these already wiuth great results.
Now that a deal!
Sent from my DROID RAZR using Tapatalk 2
wolfen
Thanks Curtis for getting back to me . I went ahead and ordered a new one from BDM parts. I`ll keep you in mind for any future work.
