moesterman
I read the post here and still have a few questions, imagine that:
What is considered a worn shoe, needs replaced?
Can the chain be adjusted correctly from the inspection window? If yes, any helpful hints? Is it just the center nylon locking nut and not the upper allen head?
If I need to remove the primary cover to make the chain adjustment should I anticipate having to replace the o-ring gasket and where can I purchase one?
Should I use silicone on the primary cover gasket like the inspection cover?
Thanks for any insight.
