prairiehorse Active Member Feb 1, 2013 #1 Will the front fender struts for a 06 K9 fit the 05 ridgeback? Curious... figure they should
phatchopper300 I just wanta ride Feb 1, 2013 #3 Th3InfamousI said: Not even close.... Click to expand... X2 Sent from my DROID RAZR using Tapatalk 2
V Guru Feb 2, 2013 #5 Curious you said "front fender" and then "struts" The "struts are on the rear fender. Might want to clarify.
Th3InfamousI Administrator Staff member Feb 2, 2013 #6 V said: Curious you said "front fender" and then "struts" The "struts are on the rear fender. Might want to clarify. Click to expand... V - Nice Catch I read right past that when I saw struts. Front Struts? - Are you referring to the front fender bracket? If so then yes it will fit.
