Thanks for your input guys. I am not sure if I am going to change the Cam as yet... It all depends on what is in there now. If there is a .546 then definitely I will be changing it... but... if there is a .569 then I might not!
There is only .16 difference between the .569 and the .585, would it be worth the hassle?
NOTE: My bike has the TP boxes if this means anything.
Cheers.
You mean .016 difference. The big difference is when it opens and closes the valves, the cam degrees are alot different.
Don't count on the cam you have in the bike having any markings on it either, my stock cam had nothing marked on it.
here are the dimensions of my old cam vs new .585
from the cam closest to cam cover back
original cam-
exh-.998 dwell to 1.345 rise
exh-.997 dwell to 1.345 rise
int-1.026 dwell to 1.378 rise
int-1.028 dwell to 1.376 rise
new .585 cam-
exh-1.005 dwell to 1.358 rise
int- 1.003 dwell to 1.358 rise
int- 1.003 dwell to 1.360 rise
