So I got my 2005 Bulldog in November and there were lots of small problems. One by one I have knocked them down, by either fixing them myself with the help of this forum, or the dealer I bought the bike from pitching in and having the bike worked on. The transmission fluid had a small leak at the drain plug so I changed the fluid and put in Royal Purple 85-140 synthetic. I used the purple so I could see the different color if it was leaking.
The latest and worst problem is it shifts terrible - clunks real hard, barely shifts at all, neutral only when the bike is shut off. I tried the clutch adjustment How-to, no luck. I tried for a couple hours one day adjusting at all different points, not happening. So I went in the primary, replaced the worn out adjustment shoe, and put in a quart of Golden Spectra 85W. Shifting was still rough. The dealer I bought the bike told me to take it to a Harley dealer - of course they told me I needed a new clutch, no surprise there. So i opened the primary again, checked the clutch nut, it was tight. I took the clutch plates out, and it is a brand new 9 plate set. The friction plates have no wear on them at all, the discs are all .120 as new. The spring height also seemed ok, about .050. I put the primary back together, removed the exhaust, and pulled off the pulley cover and what I saw was the main shaft sticking out about .200 beyond the pulley nut. It was bright silver as if it had been rubbing something, HARD:bang:. The inner access cover had a groove on the bak of it from the mainshaft rubbing it, probably .060 deep.
Here are a couple pics, any suggestions what to do next? Thanks
Dave
