ladannyd
After almost a week of searching forums after and at work I have no answer. If this discussion has taken place before plz let me know. My 05 mastiff has been giving me starting issues. It stays on a tender and when I go to crank it it spins slow. If I choke it it won't spin at all. The only way I can get it to crank is jumping it off. Which leads me to believe its the battery. My only problem with that is we load tested it at work and the tester said 451 cca. I'm not sure that is true though cause its a Harley soft ail battery which is rated at about 270-280. I'm just looking for some advice or opinions on what to try before by a part I don't need. By the way my battery reads 12.7 volts before starting and it drops to 6.5-7 Vic when I hit the start button.
