Well as some of you know, Ive been having a couple issues with my ignition system.. I'm going to start replacing stuff within the week but before I do i figured id check with the pros...It all started with a bad battery, I replaced it and it was all good for quite a while.. Then my headlight started messing up again So i jumperd it from the tail light wire, Then my nutrual light stopped working and now my oil ( assuming EHC failure ) Sometimes my tach will work perfectly normal or not work at all.. Very strange
Heres what I've done! Ive pulled tach apart checked all connections all look great and nice and tight, Pulled the controls apart checked those aswell.. They look nice and clean. Pulled tank off to check those connecters aswell all nice clean and tight. So i fiddeled with my ehc plug and that was cleaned and Dielectric grease installed. So as you can see connections have been very throughtly checked and re-checked.. Ive had the multi-meter out for weeks now battery is perfect brand new less then a week old. Connecters all have good power.. I re-did some of my grounds the one on the battery and the one leading the the frame. So now that we have that out of the way here is what Ive done.. I purchased a cam sensor from bigdog, I got it rode for about 15 mins started doing the same old stuff... Had to get it towed wouldnt run long enough to even concider getting it home.. It would run for 3 seconds then die, So i sent that cam sensor back they sent me a new one, Ive since installed it have not rode anywhere but let it idle for a while, It didnt die but im sure it would...So this week I will be ordering my Dyna 2k ignition and getting that installed hoping that fixes my issues.. Suggestions thoughts comments?
