Got a bunch of lowers if ya need one?? They're used but polish up nice.
http://www.bigdogbiker.com/forums/swap-meet/32567-chrome-lower-kickstand.html
I have 2 throttle/return that are yours if you want them. They were Harley cables so I had to use a longer butterfly adapter on my carb. They are in great condition but I bought new cables just to go back to the originals and don't plan on using them.Guess I'll call tomorrow for replacement and get some throttle cables. My return cable is broken also
Sent from my DROID RAZR using Tapatalk 2
I have an 05 chopper kickstand for you - pm me your address and I'll ship it your way.Guess I'll call tomorrow for replacement and get some throttle cables. My return cable is broken also
Thanks Dingo. Let me know how much and I'll fix you up. Raywood59@Gmail.comI have an 05 chopper kickstand for you - pm me your address and I'll ship it your way.
Good to know :2thumbs:Hi Ray, I was sent to loctite seminars through where I worked. If you don't clean the bolt with electrical contact cleaner and the bolts before you apply the loctite it will not harden properly as it is an anerobic which hardens in the lack of air (oxygen). Even if you touch the threads of the bolt with your fingers the oil from your fingers is enough to screw up the bond. Hope this helps!:flag:
I always used Lacquer Thinner or brake cleaner to get rid of the oil and whatever else was in the threads, but it also leaves a white film. I'll have to try some electrical juice. ThanksHi Ray, I was sent to loctite seminars through where I worked. If you don't clean the bolt with electrical contact cleaner and the bolts before you apply the loctite it will not harden properly as it is an anerobic which hardens in the lack of air (oxygen). Even if you touch the threads of the bolt with your fingers the oil from your fingers is enough to screw up the bond. Hope this helps!:flag:
I agree with Franco that is good to know. :2thumbs:Good to know :2thumbs:
What did you do with my bike? I had Carmen here so that is a good excuse to not come to work!As usual I repaired his scoot this morning and he is no where to be found. Hes my bro and I love him but he can be a real jackazz sometimes.
