Sure sounds like it. Replace it with a Daytona Twin Tec Ignition Kit. Kit comes with internal Ignition, single fire coil and new plug wires.The motor is turning over but there is no spark I have tested it by using a spark plug against the motor . The red LED on the ignition module blinks one time. Could it be my electronic ignition that has gone bad.
If you got power to the coil, whose to say it's the ignition module and not just the coil? Instead of wasting $400 when it could just be a $40 part.Sure sounds like it. Replace it with a Daytona Twin Tec Ignition Kit. Kit comes with internal Ignition, single fire coil and new plug wires.
Drag-Specialties part number 2101-0242
$378.95 retail.
You can test voltage going out of ignition box under seat. Should have battery voltage going in and out.
I have power to the coil but nothing to the plugs.
I'd be checking/changing the cam sensor (considering that's what makes the LED on the ignition module blink) if you have power the ignition module and coil but no spark...The motor is turning over but there is no spark I have tested it by using a spark plug against the motor . The red LED on the ignition module blinks one time. Could it be my electronic ignition that has gone bad.
