04 PitBull Wheel bearings
know the #'s for the newer dogs but don't know if they are the same for the older dogs.
rear- timken/fafnir 205KDD2 (need 3 of them)
front- timken/fafnir 204pp4 z22-p (need 2 of them)
you need to verify.
Try BCR bearings in Wichita. They are the original source for BDM. 316-265-0668
05 old dog
just replaced the wheel bearings on an 04 bulldog...the rears were the same as listed above...the fronts were a timkin tapered bearing...#11949...note...make sure on the rear you have them order the 205kdd 2...the last 2 is very important...it indicates an altered bearing...a 205kdd will NOT fit...
Not sure if the 04 is diff. than the other years, but everything else seems to be. was last year for that style, then everything changed for 05 and up. My Dealer the bike came from only has listings for 05 and up...but he said if he had the 04 BD part # he could get them...Thanks
I have the 250 series tire on rear
Have no clue if the Bull dog and Pit Bull run the same bearings...Thanks
BroadBand
Since late 60's
2004 Pitbull Parts List
Part #-----------Description---------Quanity----List Price---Dealer Price
FRAME ASSEMBLY
BDM100-00025 S&S 107CI ENG,STNDRD POL 1.00 EA 6,750.00 5,400.00
BDM100-00001 TIMER CUP SCREW 1.00 EA 3.50 2.50
BDM240-00071 5/16 LOCK WASHER 2.00 EA 0.40 0.28
BDM170-00009 ROTOR 1.00 EA 4.00 2.50
BDM100-00004 FITTING ELBOW/FXD,FX (5PK) 2.00 EA 4.00 2.00
BDM100-00013 POINTS COVER, NEW BD LOGO 1.00 EA 25.00 17.00
BDM240-00307 5/16-18 X 3/4 SC ALLEN-POLISH 4.00 EA 1.17 0.82
BDM240-00308 5/16-18X1 SOCKET CAP SCREW SSP 3.00 EA 0.80 0.70
BDM240-00309 5/16-18 X 1 1/4 SC ALLEN 1.00 EA 0.80 0.70
BDM170-00139 32 AMP STATER 1.00 EA 83.00 58.00
BDM170-00140 ALTERNATOR ROTOR 1.00 EA 125.00 87.00
BDM100-00374 3/8" S/S BRAIDED HOSE 1.00 FT 3.30 2.30
BDM100-00017 DOUBLE END THREADED STUD 4.00 EA 1.45 1.00
BDM240-00411 17.5 EAR TYPE CRIMP CLAMP 1.00 EA 1.07 0.75
BDM240-00414 BUSHING 1/4" X 1/8" 1.00 EA 0.92 0.65
BDM110-00074 SPROKET SHAFT W/ NUT&KEY 1.00 EA 85.50 58.50
BDM120-00073 POINTS COVER GASKET 1.00 EA 1.75 1.20
BDM100-00023 SPARK PLUG 2.00 EA 2.75 1.75
BDM170-00147 TRIGGER PLATE, 17" WIRES, 2003 1.00 EA 56.00 38.00
BDM100-00027 SUPERGCARBW/4 PORTW/O MANI&A/C 1.00 EA 260.00 195.00
BDM100-00030 (Kit) - FRT MANIFOLD MNT FLANGE 1.00 EA 4.65 2.90
BDM100-00031 (Kit) - FLANGE,MOUNTING,MANIFOLD,REAR 1.00 EA 4.65 2.90
BDM100-00032 (Kit) - O-RING,MANIFOLD,SS HEADS 2.00 EA 2.00 1.25
BDM100-00033 MANIFOLD,INT2-1/16"#6G-POL 1.00 EA 75.00 50.00
BDM100-00188 CRANKCASE ASSEMBLY 1.00 EA 1,105.00 850.00
BDM100-00041 (Kit) - TIMING MECHANISM SCREW(EA) 2.00 EA 3.15 2.21
BDM100-00042 (Kit) - BILLET CAM COVER POL 31-0289 1.00 EA 398.00 285.00
BDM100-00043 PINION SHAFT BEARING-WHITE 1.00 EA 26.50 18.50
BDM100-00044 OILPMPKITINCL33-4230,4232,4241 1.00 EA 280.00 195.00
BDM100-00375 107ci Flywheel Assembly 1.00 EA 880.00 680.00
BDM100-00050 PINION GEAR - YELLOW 1.00 EA 71.00 50.00
BDM100-00051 (Kit) - .110 steel breather gear shim 1.00 EA 3.75 2.25
BDM100-00052 (Kit) - Pinion gear nut - 54- 89 Big 1.00 EA 6.25 4.25
BDM100-00053 (Kit) - Pinion shaft drive gear spacer 1.00 EA 3.15 2.15
BDM100-00056 CAMSHAFT, .520 LIFT 1.00 EA 160.00 115.00
BDM100-00057 (Kit) - CAM LOCK WASHER 1.00 EA 3.00 2.00
BDM100-00058 (Kit) - CAM THRUST WASHER 1.00 EA 1.25 0.75
BDM100-00059 (Kit) - GUIDE, FRONT, TAPPET 1.00 EA 125.00 85.00
BDM100-00060 (Kit) - GUIDE, REAR, TAPPET 1.00 EA 125.00 85.00
BDM100-00063 (Kit) - ASSEM. W/HL2T,HYD. TAP 4.00 EA 50.00 34.00
BDM100-00064 SCREW,SHC,5/16-18X1",ZINC 2.00 EA 0.70 0.45
BDM100-00065 (Kit) - SCREW,HHCS,5/16-18X1" 2.00 EA 1.90 1.25
BDM100-00066 (Kit) - WASHER,FL,5/16X11/16X1/16 2.00 EA 0.65 0.40
BDM100-00067 (Kit) - WASHER, V2 HEAD BOLT 8.00 EA 1.20 0.75
BDM100-00069 DOWEL PIN 4.00 EA 0.85 0.60
BDM100-00071 4" BORE LB PACKET 1.00 EA 6.75 4.50
BDM100-00074 HEADKIT,4"bore,nostud-Std POL 1.00 EA 995.00 775.00
BDM100-00080 (Kit) - ROCKER ARM SHAFT-SET OF 4 1.00 EA 30.00 20.00
BDM100-00081 (Kit) - ROLLER ROCKER ARMS(SET) 1.00 EA 340.00 232.00
BDM100-00376 107ci DC CHROME ROCKER BOX SET 1.00 EA 525.00 360.00
BDM100-00085 ELEC COMPRESSION RELEASE KIT 1.00 EA 250.00 180.00
BDM100-00088 Cylndr Set,F&R,4"bore-Std POL 1.00 EA 775.00 550.00
BDM100-00093 BASE GASKET 2.00 EA 5.75 3.00
BDM100-00094 HEAD GASKET(SS93-1071) 2.00 EA 7.00 4.50
BDM100-00097 BOLT,SHORT,HEAD,2.47,V2 4.00 EA 10.75 7.35
BDM100-00098 (Kit) - HEAD BOLT KIT,LONG (93-3029-S) 4.00 EA 11.55 7.95
BDM100-00102 (Kit) - PUSHROD TUBE O-RING KIT 1.00 EA 5.75 4.00
BDM100-00103 (Kit) - PUSHROD COVER KIT(SET OF 4) 1.00 EA 113.00 78.00
BDM100-00104 KEEPER, PUSHROD TUBE COVERS(4) 1.00 EA 11.45 8.80
BDM100-00105 PUSHROD SET, ADJ. - -.175 S 1.00 EA 79.00 55.00
BDM100-00107 PISTON RING,TOP COMP., 4"STD 2.00 EA 5.25 4.00
BDM100-00108 PISTON RING,2ND COMP., 4"STD 2.00 EA 5.25 4.00
BDM100-00109 PISTON RING,EXPAND,4"STD/+.010 2.00 EA 5.25 4.00
BDM100-00110 PISTON RING,OIL RAIL, 4"STD 4.00 EA 5.25 4.00
BDM240-00440 CABLE GUIDE 1.00 EA 3.25 2.00
BDM100-00118 Oil Filter Housing - Chrome 1.00 EA 41.00 28.00
BDM100-00036 ENRICHNER LEVER-BIG DOG STYLE 1.00 EA 9.00 6.00
BDM110-00041 6-SPEED TRANS, SOFTAIL, 2004 1.00 EA 2,990.00 2,105.00
BDM240-00003 RETAINING RING (PACKS OF 10) 1.00 EA 0.75 0.50
BDM120-00001 OIL SEAL (PACKS OF 10) 1.00 EA 3.25 1.95
BDM110-00001 OIL SEAL 1.00 EA 6.00 4.50
BDM120-00003 CLUTCH PUSHROD BEARING KIT 1.00 EA 13.00 9.00
BDM110-00002 RAMP, INNER 1.00 EA 12.50 9.50
BDM120-00537 RAMP 1.00 EA 4.75 3.00
BDM240-00059 5/16-24 X 1 SC ALLEN 1.00 EA 0.95 0.65
BDM110-00006 INNER RACE BEARING 1.00 EA 15.00 10.00
BDM110-00008 COUPLING 1.00 EA 6.50 4.00
BDM110-00014 TRANSMISSION VENT HOSE 1.00 EA 2.25 1.50
BDM110-00017 GSKT-N.SWITCH33043-80(10) 1.00 EA 0.50 0.30
BDM110-00019 CHECKBALL-O/PUMP 8873(10) 3.00 EA 0.55 0.35
BDM240-00136 1/8 NPTX1/4" HOSE FITTING, ELB 1.00 EA 3.50 2.50
BDM110-00054 LSD TRANSMISSION PULLEY 1.00 EA 65.00 43.00
BDM110-00055 BELT SPROCKET SPACER 1.00 EA 10.00 7.00
BDM110-00062 6-SP GEAR SET - RED. NEUTRAL 1.00 EA 2,250.00 1,700.00
BDM110-00067 TRANS TOP COVER BOLT KIT 1.00 EA 9.00 6.25
BDM240-00304 1/4-20 X 2 SC ALLEN-POLISHED 2.00 EA 1.24 0.87
BDM240-00305 1/4-20X2 1/4 SC ALLEN-POLISHED 4.00 EA 1.30 0.91
BDM240-00315 1/4 AN WASHER-POLISHED 6.00 EA 0.29 0.20
BDM240-00328 ZINC 7/16X1-1/8"O.D.FLATWASHER 2.00 EA 0.47 0.32
BDM240-00386 7/16-14 JAM NUT 1.00 EA 0.09 0.06
BDM110-00075 SOFTTAIL TRANS CASE 1.00 EA 285.00 200.00
BDM240-00435 7/16-14 X 1/2 SKT SET SCREW 1.00 EA 0.57 0.40
BDM170-00150 04 NEUTRAL SWITCH 1.00 EA 5.50 3.70
BDM110-00083 SHIFT ROD RETAINING RING(10PK) 1.00 EA 0.45 0.30
BDM110-00085 SHIFTER ARM ADJUSTER SCREW 1.00 EA 9.00 6.00
BDM120-00087 DRIVE PULLEY INSTALLATION KIT 1.00 EA 11.00 7.00
BDM110-00086 TRANS SHIFTER LEVER CHROME 1.00 EA 16.50 10.50
BDM110-00088 TRANS TOP COVER - CHROME 1.00 EA 50.00 33.00
BDM110-00053 TRANS SIDE COVER, CHROME 1.00 EA 46.00 33.10
BDM110-00146 FILLER DIPSTICK 1.00 EA 13.25 9.25
BDM120-00063 FINAL DRIVE, 2004 PITBULL 1.00 EA 3,250.00 2,200.00
BDM120-00002 SEAL 1.00 EA 6.00 4.00
BDM120-00004 SPACER 060 1.00 EA 5.25 3.75
BDM120-00005 SPACER, FLST,FXRT,FLTC,ULTRAS 1.00 EA 4.00 2.65
BDM240-00049 5/16-18x3 ScktCap Allen,SS Pol 2.00 EA 1.75 1.15
BDM120-00006 LOCKPLATE 1.00 EA 0.60 0.38
BDM120-00007 BUSHING, JACKSHAFT 1.00 EA 4.00 2.75
BDM120-00008 BUSHING 1.00 EA 3.80 2.60
BDM120-00009 REVTECH PRIMARY LUBE (12/Case) 2.00 EA 4.50 3.00
BDM110-00009 REVTECH TRANSMISSION LUBE (12) 1.00 EA 5.25 3.50
BDM110-00016 SEAL L84UP TRAN 12052 (5) 1.00 EA 3.00 2.00
BDM110-00023 MAGNETIC PIPE PLUG 1.00 EA 2.35 1.35
BDM120-00020 HDP ROLLER BEARING 1.00 EA 22.00 13.50
BDM120-00031 CLUTCH CBL W/CLR COAT-NO SPRG 1.00 EA 61.48 43.30
BDM170-00112 GEAR TOOTH SNSR-04 MODELS 1.00 EA 81.00 56.50
BDM130-00194 REGULATOR HOLD DOWN SPACER 2.00 EA 2.30 1.65
BDM120-00035 INSPECTION COVER, POLISHED 1.00 EA 18.00 12.00
BDM120-00046 DRIVE BELT, 130 TOOTH-SOFTAIL 1.00 EA 130.00 100.00
BDM100-00123 Oil,SAE 20W50,Revtec,Std 12/Cs 1.00 EA 3.75 2.50
BDM240-00279 3/8 THIN WALL NYLOCK(100/BX) 1.00 EA 0.33 0.23
BDM120-00049 89-94 ST PRI,INS CVR BOLT KIT 1.00 EA 30.25 21.75
BDM240-00295 1/4-20x5/8"POL COUNTER SUNK 1.00 EA 0.90 0.60
BDM240-00340 5/16-18 x 2 3/4 Hex, Gr5 4.00 EA 0.24 0.17
BDM240-00341 5/16-18 X 3" HEX HEAD BOLT 2.00 EA 0.24 0.17
BDM240-00345 1/4-28x2"GRADE 5 HEX BOLT,ZINC 2.00 EA 0.13 0.09
BDM240-00350 5/16-18X21/4"SOCKET CAP ALLEN 2.00 EA 0.32 0.22
BDM240-00351 5/16-24x5/8"SCKT CAP ALLEN 6.00 EA 0.19 0.13
BDM240-00372 5/16 SAE FLAT WASHER 2.00 EA 0.10 0.05
BDM240-00380 5/16 LOCK WASHER 2.00 EA 0.10 0.05
BDM240-00387 7/16-20 FINE THREAD HEX NUT 1.00 EA 0.10 0.05
BDM240-00409 1/4 x 5/8 x 1/16 WASHER 2.00 EA 0.15 0.10
BDM130-00301 6 MALE FLARE-1/8"NPT FITTNG 3.00 EA 1.75 1.25
BDM130-00302 6 MALE FLARE/ 1/4"NPT STRGHT 2.00 EA 2.00 1.25
BDM130-00310 16.375" BRAIDED SS OIL LINE 1.00 EA 19.25 13.50
BDM130-00313 7.000" BRAIDED SS OIL LINE 1.00 EA 19.00 13.00
BDM100-00020 BLACK OIL FILTER 1.00 EA 11.50 8.00
BDM120-00069 1 7/16" EXTENDED COMPENSAT NUT-PB,RB 1.00 EA 19.00 13.00
BDM110-00080 CENTER CLUTCH PUSHROD BIG TWIN 1.00 EA 6.90 4.25
BDM110-00081 CLUTCH&INSP CVR WSHR/SEAL 5/PK 3.00 EA 1.35 0.90
BDM120-00071 INNER PRIMARY O-RING 1.00 EA 1.80 1.25
BDM120-00072 DERBY COVER O-RING 1.00 EA 1.35 1.90
BDM120-00076 SOFTTAIL PRIMARY COVER GASKET 1.00 EA 17.25 12.00
BDM120-00077 ST INSPECTION COVER GASKET 1.00 EA 0.80 0.55
BDM120-00078 BASKET&CLUTCH ASSY-PC-1200-C 1.00 EA 858.00 600.00
BDM170-00148 1.8KW POLISHED STARTER W/PLUGS 1.00 EA 425.00 295.00
BDM120-00081 STR JACKSHAFT ASSY(465046) 1.00 EA 120.00 80.00
BDM110-00084 MAINSHAFT SNAP RINGS (10) 2.00 EA 1.00 0.75
BDM120-00083 FST PRIMARY CHAIN - 82 PITCH 1.00 EA 52.00 36.00
BDM120-00084 CLUTCH PUSHROD ADJUSTER SCREW 1.00 EA 6.25 4.00
BDM120-00085 66 Tooth Ring Gear 1.00 EA 67.50 50.00
BDM120-00086 24 TOOTH COMPENSATING SPROCKET 1.00 EA 60.00 41.00
BDM120-00088 RETAINER&SPRNG ASSY 40384-91 1.00 EA 48.00 31.00
BDM120-00089 PRIMARY ADJUSTING SHOE 1.00 EA 3.75 2.50
BDM120-00090 PRIMARY LOCK TAB 1.00 EA 0.25 0.15
BDM120-00091 PLATE CHAIN TENSIONER 1.00 EA 1.07 0.75
BDM120-00092 PRIMARY CHAIN ADJUSTING PLATE 1.00 EA 20.00 13.00
BDM120-00093 INNER PRMR LCKPLATE&BOLT KIT 1.00 EA 7.75 5.00
BDM120-00094 ST Primary Cover - Chrome 1.00 EA 285.00 195.00
BDM120-00098 1 7/16" OFFSET INNER PRIMARY 1.00 EA 290.00 200.00
BDM120-00099 PRIMARY LOCKING TAB(25-415) 6.00 EA 0.40 0.30
BDM120-00100 1 7/16 EXT COMPENSATOR SHAFT 1.00 EA 32.05 22.10
BDM120-00105 SLIDNG CAM-COMP SPRKT 40299-83 1.00 EA 29.00 20.00
BDM130-00003 7/16 DOUBLE T-CLAMP, 3/4 SCREW 1.00 EA 1.85 1.30
BDM130-00017 JIFFYSTAND SPRING, SOFTAILS 1.00 EA 3.75 2.45
BDM130-00079 04 RB/PB VOLTAGE RGLTR SPCR 2.00 EA 2.15 1.50
BDM130-00127 TANK GRMMT BUSHING,ZINC PL.ATE 3.00 EA 2.15 1.50
BDM130-00281 FRAME KIT 250 L/D RIGID-04 PB 1.00 EA 2,750.00 1,850.00
BDM130-00301 6 MALE FLARE-1/8"NPT FITTNG 4.00 EA 1.75 1.25
BDM130-00304 6 MALE FLARE/1/4"NPT90 DEGREE 1.00 EA 5.25 3.60
BDM130-00309 15.625" BRAIDED SS OIL FEED LINE 1.00 EA 19.00 13.25
BDM130-00312 6.500" BRAIDED SS OIL LINE 1.00 EA 15.50 11.00
BDM130-00354 04 CH/MS/BD SIDEMNT KICKSTAND 1.00 EA 85.00 56.00
BDM130-00364 RUBR GRMMT-FUEL TNK MOUNT 3.00 EA 0.70 0.45
BDM130-00524 RB/PB KICKSTAND MOUNT, CHROME 1.00 EA 150.00 105.00
BDM130-00069 RB/PB KICKSTAND MOUNT 1.00 EA 125.00 80.00
BDM130-00784 RIGID BATTERY TRAY 1.00 EA 17.75 12.50
BDM130-00864 MOTOR MT ASSY-FR-250 L/D-SLOT 1.00 EA 175.00 115.00
BDM140-00078 WHEEL SUB-ASSY-2004 PB 1.00 EA 3,450.00 2,385.00
BDM240-00053 5/16-18 X 3/4 BUTTON 5.00 EA 0.90 0.65
BDM240-00099 3/8-16 X 3/4 BUTTON 5.00 EA 1.10 0.80
BDM140-00001 120/70-21 VENOM FRONT TIRE 1.00 EA 160.00 105.00
BDM140-00196 250/40HR18 8" RADIAL R TIRE 1.00 EA 278.00 181.00
BDM130-00078 7/16 SM OD S/S PULLEY WASHER 5.00 EA 1.45 0.90
BDM130-00089 PULLEY SPACER, .062 1.00 EA 11.00 7.50
BDM140-00031 PB FRNT WHEEL-21x3.25 - 2004 1.00 EA 930.00 650.00
BDM140-00032 PB REAR WHEEL-18X8.5-2004 1.00 EA 1,075.00 750.00
BDM140-00033 PB REAR PULLEY-65T-2004 1.00 EA 355.00 250.00
BDM240-00312 7/16-14 X 1-1/4 SOCKET CAP SCR 5.00 EA 6.25 3.90
BDM180-00059 '04 PITBULL FRONT ROTOR 1.00 EA 245.00 180.00
BDM180-00064 '04 PITBULL REAR ROTOR 1.00 EA 245.00 180.00
BDM170-00058 15" BATTERY CABLE 1.00 EA 17.62 12.33
BDM170-00063 4-10 14" GRND CABLE,1/4&5/16 1.00 EA 26.13 18.28
BDM170-00086 CIRCUIT BREAKER KIT 1.00 EA 11.00 7.50
BDM170-00093 04-UP ELEC HARNESS CONTROLLER 1.00 EA 194.48 136.00
BDM170-00131 12v DISC HORN 1.00 EA 10.21 7.14
BDM170-00137 VOLTAGE REGULATOR BLACK 1.00 EA 80.00 56.00
BDM170-00145 RUBBER BOOT 1.00 EA 0.60 0.45
BDM200-00040 OIL TANK MOUNTING HARDWARE KIT 1.00 EA 92.38 64.60
BDM200-00041 RIGID OIL TANK 1.00 EA 430.04 300.73
BDM240-00001 HEX HEAD PIPE PLUG 1.00 EA 2.11 1.48
BDM240-00082 3/8-16 X 1 SC ALLEN 2.00 EA 1.15 0.80
BDM240-00110 3/8 LOCK WASHER 2.00 EA 0.35 0.25
BDM240-00333 1/4-20 x 2" GR 5 HEX CAP, ZINC 2.00 EA 0.12 0.08
BDM240-00335 5/16-18x1"GR 5 HEX CAP,ZINC 2.00 EA 0.10 0.07
BDM240-00336 5/16-18X11/4"HEX,GRADE 5 ZINC 1.00 EA 0.12 0.08
BDM240-00365 8-32 x 2 1/2" MACH SCREW 2.00 EA 0.04 0.03
BDM240-00372 5/16 SAE FLAT WASHER 3.00 EA 0.10 0.05
BDM240-00375 5/16 X 1 FENDER WASHER 3.00 EA 0.06 0.04
BDM240-00385 1/4" LOCK WASHER, ZINC PLATED 2.00 EA 0.02 0.01
BDM240-00388 8-32 NYLOCK NUT 2.00 EA 0.04 0.02
BDM240-00389 5/16 NYLOCK 3.00 EA 0.05 0.03
BDM240-00417 1/4-20 THIN WALL NYLOCK (50PK) 4.00 EA 0.22 0.15
FRONT FORK INSTALL
BDM100-00204 10W FORK OIL 55 GAL DRUM 1.00 EA 7.70 5.39
BDM130-00072 WHEELSPACER, POLISHED 1.00 EA 8.00 6.00
BDM240-00144 WHEEL SPACER 1.00 EA 4.00 2.75
BDM130-00075 Wheel Spacer, Polished 1.00 EA 4.25 3.25
BDM240-00164 WHEEL SPACER 1.00 EA 3.00 2.25
BDM130-00088 WHEEL SPACER - POLISHED 1.00 EA 8.11 5.67
BDM130-00096 .500" R WHEEL SPACER;1"ID POL 1.00 EA 6.50 4.50
BDM240-00261 .500" REAR WHEEL SPACER; 1" ID 1.00 EA 3.30 2.30
BDM130-00177 BELTGUARD - POL SS 1.00 EA 128.00 90.00
BDM130-00215 41MM TREE STEM-PLATED 1.00 EA 18.00 15.00
BDM130-00217 SHAFT CAP/54MM & 41MM-PLATED 1.00 EA 7.41 5.19
BDM130-00225 Top Tree,41mm 4deg,POL 1.00 EA 140.45 98.22
BDM130-00617 41MM TOP TREE RAKED-UNPOLISHED 1.00 EA 118.75 83.05
BDM130-00226 Bottm TrplTree,41mm4degree,Pol 1.00 EA 155.64 108.84
BDM130-00619 41mm TRPL TREE,BOTTM NEW DSIGN 1.00 EA 133.95 93.67
BDM130-00242 NECK BEARING RACE 2.00 EA 4.75 3.00
BDM130-00243 TIMKN BERNG CS160002 NECK BRNG 2.00 EA 10.00 7.50
BDM130-00257 250 RIGID RECESSED AXLE KIT 1.00 EA 114.00 80.00
BDM130-00295 FORK CAP WASHERS 2.00 EA 0.81 0.56
BDM130-00324 NECKCUP W/FORK STOP KIT 1.00 EA 135.00 95.00
BDM130-00330 41MM FORK SET + 2" FXST LENGTH 1.00 EA 765.00 500.00
BDM150-00069 HANDLEBAR RUBBER BUSHINGS STK 1.00 EA 8.50 5.75
BDM180-00034 POL, R BRAKE CALIPER BRACKET 1.00 EA 86.00 60.00
BDM180-00126 REAR BRAKE CALIPER BRACKET 1.00 EA 64.00 45.00
BDM240-00067 5/16-24 x 5/8 Socket Cap Allen 2.00 EA 0.90 0.70
BDM240-00074 5/16 FLAT WASHER 2.00 EA 0.35 0.25
BDM240-00277 WHEEL SPACER - POLISHED 1.00 EA 6.03 4.22
BDM240-00276 WHEEL SPACER 1.00 EA 3.30 2.30
BDM240-00283 3/8-16x11/4" SOCKET SET SCREW 2.00 EA 0.70 0.49
BDM240-00288 3/8-16 X 1/2 SOCKET SET SCR-SS 2.00 EA 1.19 0.83
BDM240-00309 5/16-18 X 1 1/4 SC ALLEN 4.00 EA 0.80 0.70
BDM240-00324 10-24 X 1/2 FLAT HEAD TORX 4.00 EA 0.32 0.22
BDM240-00398 5/16"18X3/8AL CUP BLOX SETSCRW 2.00 EA 0.16 0.11
HANDLEBAR INSTALL
BDM130-00123 11/2" CLUTCH CABLE CLAMP,POL 2.00 EA 29.00 19.75
BDM130-00681 1 1/2" CLUTCH CABLE CLAMP 1.00 EA 20.00 14.00
BDM150-00068 HANDLEBAR WASHER KIT(SET OF 4) 1.00 EA 18.23 12.75
BDM150-00073 04 PB/MS HANDLEBAR SUB-ASSY 1.00 EA 1,310.00 903.45
BDM240-00025 1/4-20 x 9/16"SOCKET CAP ALLEN 4.00 EA 1.37 0.96
BDM150-00006 THROTTLE CABLE - 34" - 04 1.00 EA 43.00 30.00
BDM150-00008 IDLE CABLE - 34" - 04 1.00 EA 50.00 35.00
BDM150-00038 LH HANDLEBAR CONTROL PCB ASSY 1.00 EA 40.00 26.00
BDM170-00088 04 PB/MS HANDLEBAR HARNESS 1.00 EA 38.56 26.96
BDM240-00358 1/4-20 X 3/8 SOCKET SET SCREW 2.00 EA 0.17 0.12
BDM240-00362 4-40 x 3/8" PANHEAD SCREW 8.00 EA 0.03 0.02
BDM240-00399 10-24x3/8"SCKT CAP SCRW,ZINC 2.00 EA 0.17 0.12
BDM240-00426 4-40 x 1/8" SS SET SCREW 1.00 EA 0.29 0.20
BDM240-00436 8-32 x 3/16" SET SCREW 2.00 EA 0.09 0.06
BDM150-00079 THROTTLE/IDLE CABLE FERRULES 2.00 EA 0.52 0.36
BDM150-00196 HANDLEBARS -04 PB/MF-CHR/LASER 1.00 EA 459.00 321.00
BDM150-00207 LH HANDLEBAR CONTROL 1.00 EA 207.25 145.00
BDM150-00203 CLUTCH SIDE HANDGRIP 1.00 EA 58.00 40.00
BDM150-00204 THROTTLE SIDE HAND GRIP 1.00 EA 70.00 48.00
BDM150-00206 RH HANDLEBAR CONTROL 1.00 EA 275.00 192.00
BDM150-00082 '04 RH SIDE MIRROR 1.00 EA 40.00 26.00
BDM150-00083 '04 LH SIDE MIRROR 1.00 EA 40.00 26.00
BDM240-00063 5/16-24 1 3/4 HEX 1.00 EA 0.94 0.66
BDM240-00064 5/16-24 x 2 Hex Cap Screw 1.00 EA 1.03 0.72
BDM240-00301 1/2-13 X 2-1/2 HX CAP,POLISHED 2.00 EA 2.10 1.70
BRAKES
BDM160-00001 NYLON WASHER 2.00 EA 0.10 0.05
BDM160-00002 WASH, .43 ISx .63 OD x .09 TH,NYL 4.00 EA 0.10 0.05
BDM160-00023 RH FWD CONTROL MOUNTING PLATE 1.00 EA 20.00 14.00
BDM160-00024 END CAP, SMALL PEG 2.00 EA 9.00 6.00
BDM160-00025 04 SHIFT LINKAGE 1.00 EA 53.00 37.00
BDM160-00082 ASSY, SHIFT SIDE FWD CONTROL 1.00 EA 250.00 175.00
BDM160-00060 BODY, SHIFT CONTROL, STD 1.00 EA 120.00 70.00
BDM160-00058 LEVER, CLUTCH CONTROL PEG 1.00 EA 65.00 47.00
BDM160-00059 LEVER, SHIFT CONTROL LINK 1.00 EA 0.00 0.00
BDM160-00057 AXLE, FOOT CONTROL 1.00 EA 0.00 0.00
BDM160-00056 CLEVIS, FORWARD CONTROL 1.00 EA 28.00 19.00
BDM240-00493 1/2-13 X 2 1/2 HEX CAP SCREW 1.00 EA 0.00 0.00
BDM240-00492 8-32 X 5/8 SHCS, SS 3.00 EA 0.00 0.00
BDM240-00396 .125" x .250" SS DOWEL PIN 2.00 EA 0.13 0.09
BDM160-00054 BUSHING, 1"IDX1.125"ODX1.50L 1.00 EA 0.00 0.00
BDM160-00055 U-SEAL, 1.25IDX1.563XODX.156 2.00 EA 0.00 0.00
BDM160-00116 LG PEG-FORWARD CONTROL-LEFT 1.00 EA 70.00 45.00
BDM160-00127 LG PEG-FORWARD CONTROL-RIGHT 1.00 EA 70.00 45.00
BDM160-00134 SM PEG-FORWARD CNTRL 2.00 EA 23.00 15.00
BDM160-00209 ASSY, BRAKE FORWARD CONTROL 1.00 EA 342.00 239.00
BDM160-00061 LEVER, FOOT BRAKE CONTROL 1.00 EA 0.00 0.00
BDM160-00066 PUSHROD - MASTER CYL, 1.00 EA 0.00 0.00
BDM160-00064 COVER, MASTER CYLINDER 1.00 EA 0.00 0.00
BDM160-00062 WSHR,PISTON RETANR-04 HBCNTRL 1.00 EA 2.07 1.45
BDM160-00063 BODY, REAR BRAKE M/C 1.00 EA 0.00 0.00
BDM160-00065 BOOT,BRAKE PUSHROD-04 HB CNTRL 1.00 EA 3.38 2.36
BDM160-00210 MASTER CYLINDER PISTON 1.00 EA 6.50 4.50
BDM160-00070 SPRING FOLLOWER, 04 HB CNTRL 1.00 EA 2.10 1.45
BDM160-00067 SPRING, M/C, LONG 1.00 EA 0.00 0.00
BDM160-00069 CUP, 5/8, MS-04 HB CONTROLS 1.00 EA 2.42 1.67
BDM160-00072 BRAKE M/C GASKET,04 HB CNTRL 1.00 EA 3.00 2.00
BDM160-00068 O-Ring, Rear Piston Seal 1.00 EA 0.00 0.00
BDM160-00003 SNAP RING, MC REPAIR KIT 1.00 EA 0.00 0.00
BDM240-00494 Dowel, 0.250 X 0.750, SS 1.00 EA 0.00 0.00
BDM160-00055 U-SEAL, 1.25IDX1.563XODX.156 1.00 EA 0.00 0.00
BDM170-00041 BRK LIGHT SWTCH W/TERM LEAD 1.00 EA 31.95 22.50
BDM170-00040 BRAKELIGHT SWITCH W/ WIRELEADS 1.00 EA 33.00 23.00
BDM170-00310 20mm MOD BRAKE SWITCH 1.00 EA 28.50 20.00
BDM170-00327 20mm REAR BRAKE SWITCH 1.00 EA 14.25 10.00
BDM180-00008 BRAKE LINE KIT - 2004 PITBULL 1.00 EA 96.00 67.50
BDM180-00031 FRNT BRAKELINE BRACKET,POL 1.00 EA 11.05 6.85
BDM180-00030 FRONT BRAKELINE BRACKET 1.00 EA 7.08 4.95
BDM180-00033 FRNT CALIPER BRACKET-PRE-POL 1.00 EA 27.48 19.22
BDM180-00037 Brake Fluid (CASE OF 6) 0.75 EA 8.25 5.50
BDM180-00040 3/16" BRAKELINE FITTING CLAMP 1.00 EA 0.67 0.46
BDM180-00045 CALIPER POLISHED 2.00 EA 300.00 220.00
BDM240-00006 10-24 X 1/2 BUTTON 1.00 EA 1.05 0.65
BDM240-00026 1/4-20X5/8 HEX 1.00 EA 1.05 0.65
BDM240-00036 1/4 LOCK WASHER 1.00 EA 0.35 0.25
BDM240-00037 1/4 FLAT WASHER 1.00 EA 0.40 0.28
BDM240-00069 5/16-24 x 3/4 BUTTON - CHROME 1.00 EA 1.19 0.83
BDM240-00081 3/8-16 X 1 BUTTON 2.00 EA 1.11 0.78
BDM240-00082 3/8-16 X 1 SC ALLEN 3.00 EA 1.15 0.80
BDM240-00084 3/8-16 X 1 1/8 SC ALLEN 2.00 EA 1.60 1.15
BDM240-00092 3/8-16 X 1 3/4 SC ALLEN 4.00 EA 1.15 0.80
BDM240-00101 3/8-16 x 7/8" SC ALLEN 1.00 EA 1.43 1.01
BDM240-00112 3/8 FLAT WASHERS 2.00 EA 0.38 0.27
BDM240-00296 5/16-18 X 1 1/4 TAPERED ALLEN 1.00 EA 1.10 0.80
BDM240-00313 10-32X1/2 SOCKET CAP SCREW POL 1.00 EA 1.05 0.65
BDM240-00316 3/8 AN WASHER 4.00 EA 0.30 0.22
BDM240-00384 1/2" INTERNAL TOOTH LCKWSHR 1.00 EA 0.10 0.07
BDM240-00395 1/4"-20 x 3/4" SHOULDER SCREW 2.00 EA 1.90 1.30
BDM240-00396 .125" x .250" SS DOWEL PIN 4.00 EA 0.13 0.09
BDM240-00407 3/8-16x1" FLAT HEAD SC, ZINC 1.00 EA 0.40 0.27
BDM240-00413 RUBBERIZED PINCH CLAMP 1.00 EA 1.19 0.83
BDM240-00416 10-32 THIN NYLOCK, PKG OF 50ea 1.00 EA 0.20 0.13
BDM240-00625 1/4-20 x 3 1/2" FLAT HEAD SCREW PAR THRD 2.00 EA 1.80 1.25
WIRING
BDM130-00038 '03 DASH MOUNT BASE BRACKET 1.00 EA 14.25 10.00
BDM130-00040 '03 "Y" DASH MOUNT POST 1.00 EA 18.50 13.00
BDM130-00042 '03 "V" ADJUSTMENT MOUNT 1.00 EA 10.50 7.25
BDM130-00043 DASH MOUNT STAND OFF 1.00 EA 7.50 5.25
BDM130-00211 BATTERY PAD - 2003 HK/BD/PB 1.00 EA 2.70 1.65
BDM130-00236 Signal Wire Retainer - POL 1.00 EA 10.78 7.54
BDM130-00235 SIGNAL HARNESS RETAINER-TREES 1.00 EA 6.44 4.51
BDM130-00332 STRAP,BATTERY 66105-77 1.00 EA 4.25 2.50
BDM130-00711 RIGID IGN MODULE MOUNTING BRKT 1.00 EA 5.45 3.81
BDM170-00032 04 IGN MODULE - DUAL FIRE 1.00 EA 200.00 135.00
BDM170-00049 04 PB MAIN HARNESS 1.00 EA 235.00 165.00
BDM170-00056 04 PB COIL WIRE 1.00 EA 1.60 1.12
BDM170-00064 BATTERY TERMINAL SPACER 2.00 EA 1.75 1.25
BDM170-00091 SNSR PLATE HRNSS-PB&RB 1.00 EA 10.00 7.00
BDM170-00151 BATTERY (YTX20L-BS) 1.00 EA 78.00 50.00
BDM240-00009 10-32 X 3/4 BUTTON 1.00 EA 1.10 0.70
BDM240-00010 10-32 CHROME ACORN NUT 1.00 EA 1.10 0.70
BDM240-00334 5/16-18x3/4"GR 5 HEX CAP,ZINC 2.00 EA 0.09 0.06
BDM240-00349 1/4-20 x 3/4 SOCKET CAP ALLEN 2.00 EA 0.18 0.12
BDM240-00357 5/16 -18 BY 1 TAPERED ALLEN 2.00 EA 0.23 0.16
BDM240-00366 10-32x1 MACHINE SCRW-PHILLIPS 2.00 EA 0.07 0.05
BDM240-00378 #10 LOCKWASHER, ZINC 2.00 EA 0.10 0.05
Wiring Bolt-On
BDM130-00054 L-BRCKT,CHR UPPER ENG MOUNT 1.00 EA 18.56 12.98
BDM130-00359 SPCR-FRNT TURN SGNL-CHR 2.00 EA 4.25 2.60
BDM130-00825 TURNSIGNAL HOUSING,BOOT&CLEAR/CIRCLE LEN 2.00 EA 13.25 9.25
BDM170-00077 04 MS/PB FRNT TURNSGNL HRNSS 1.00 EA 14.56 10.18
BDM170-00127 LED TRNSGNL BOARD,AMBER,DUAL 2.00 EA 57.00 35.00
BDM240-00085 3/8-16 X 1 1/4 HEX 1.00 EA 0.94 0.66
BDM240-00087 3/8-16 X 1 1/4 SC ALLEN 2.00 EA 1.35 0.85
BDM240-00110 3/8 LOCK WASHER 3.00 EA 0.35 0.25
BDM240-00112 3/8 FLAT WASHERS 3.00 EA 0.38 0.27
BDM240-00347 1/2-20x11/2"HEX CAP SCRW,ZINC 1.00 EA 0.35 0.24
BDM240-00373 1/2" FLAT WASHER 1.00 EA 0.07 0.05
BDM240-00381 1/2" LOCK WASHER - ZINC COATED 1.00 EA 0.06 0.04
BDM240-00382 5/16" INTERNAL TOOTH LCKWSHR 2.00 EA 0.03 0.02
WIRING PREASSEMBLY
BDM130-00133 WASHER PLATE, IGN COIL-.125" 1.00 EA 1.99 1.40
BDM130-00136 107ci COIL COVER - LASER ENG 1.00 EA 74.15 51.85
BDM130-00135 107ci CHROME COIL COVER 1.00 EA 95.00 60.00
BDM170-00001 8.8mm PLUG WIRE SET 1.00 EA 17.46 12.21
BDM170-00070 04 DUALTNK COIL/IGN SWTCH HRNS 1.00 EA 13.00 9.00
BDM170-00135 COIL 1.00 EA 68.50 48.00
BDM170-00144 IGNITION SWITCH 2003 1.00 EA 59.00 41.00
BDM240-00329 3/16" BLACK NYLON CLAMP 2.00 EA 0.13 0.09
BDM240-00331 1/4-20x11/4"HEX CAP SCRW,ZINC 2.00 EA 0.08 0.06
BDM240-00370 #10 ZINC PLATED WASHER 2.00 EA 0.02 0.02
BDM240-00402 10-24 x 3/8" BUTTON HEAD, ZINC 2.00 EA 0.26 0.18
BDM240-00431 3/8 FIBERGLASS FLAT WASHER 2.00 EA 0.50 0.30
LICENSE TAG SUBASSEMBLY
BDM130-00203 03 TAG PLATE TRIM RING,POL 1.00 EA 30.44 21.28
BDM130-00611 '03 TAG PLATE TRIM RING 1.00 EA 21.76 15.22
BDM130-00204 03 TAG PLATE LIGHT BEZEL,POL 1.00 EA 31.32 21.90
BDM130-00700 '03 TAG PLATE LIGHT BEZEL 1.00 EA 29.00 20.00
BDM130-00205 '03 TAG BEZEL LENS 1.00 EA 7.75 5.00
BDM130-00207 03 LICENSE TAG PLATE,POL 1.00 EA 53.00 37.00
BDM130-00693 '03 TAG PLATE 1.00 EA 32.00 22.00
BDM130-00208 '03 TAG PLATE MOUNT, POLISHED 1.00 EA 20.52 14.35
BDM130-00670 '03 TAG PLATE MOUNT 1.00 EA 12.20 8.50
BDM130-00333 NYLON SPACER 1.00 EA 0.08 0.05
BDM170-00119 04 PB/RB LED TAG LIGHT 1.00 EA 28.86 20.18
BDM240-00034 1/4-28 X 1/2 BUTTON 2.00 EA 1.00 0.70
BDM240-00343 1/2-13X11/4 HEX CAP SCRW-ZINC 1.00 EA 0.31 0.21
BDM240-00363 6-32x5/16" PAN HEAD SCRW,ZINC 2.00 EA 0.02 0.02
BDM240-00364 8-32x5/8"MACHINE SCRW, ZINC 1.00 EA 0.05 0.04
BDM240-00406 1/4-20 X 1/2 FLATHEAD SC ALLEN 4.00 EA 0.24 0.16
WIRING PREASSEMBLY
BDM130-00036 AUTOMETER SPEEDOMETER BRACKET 1.00 EA 5.75 4.00
BDM130-00196 POLISHED HEADLIGHT MOUNT 1.00 EA 22.00 15.00
BDM130-00351 5 3/4"HOODED HEADLIGHT ASSY 1.00 EA 200.00 130.00
BDM170-00103 04 RB/PB/MS HEADLIGHT HARNESS 1.00 EA 20.74 14.50
BDM170-00405 5 3/4" LENS REFLECTOR 1.00 EA 30.00 20.00
BDM170-00406 HALOGEN HEADLIGHT BULB 1.00 EA 5.75 4.00
BDM170-00407 LENS REFLECTOR GASKET 1.00 EA 1.45 1.00
BDM240-00099 3/8-16 X 3/4 BUTTON 2.00 EA 1.10 0.80
BDM240-00393 #139 O-RING 1.00 EA 0.16 0.11
REAR FENDER ASSEMBLY
04 PB FENDER STRUT, RH POLISHED 1.00 EA
BDM130-00796 04 PB FENDER STRUT, RH 1.00 EA 69.00 48.00
04 PB FENDER STRUT 1.00 EA
BDM130-00004 5/16-18 x 1 1/4" TURNSIGN BOLT 2.00 EA 2.50 1.75
BDM130-00823 TURNSIGNAL HOUSING, REAR 2.00 EA 13.25 9.25
BDM170-00010 04 120 mph SPEEDO W/ 3" PIGTAI 1.00 EA 285.00 185.00
BDM170-00097 04 RIGID REAR FENDER HARNESS 1.00 EA 14.25 10.00
BDM170-00128 LED TRNSGNL BOARD,RED,DUAL 2.00 EA 57.00 35.00
BDM170-00409 AMP FEMALE FAST ON RED(HORN,CR) 2.00 EA
BDM240-00356 3/8-16X1/2 BUTN HEAD -BLK 6.00 EA 0.28 0.19
BDM240-00424 FENDER GROMMET, PKG OF 50ea 1.00 EA 0.30 0.21
FINAL CHASSIS ASSEMBLY
BDM100-00014 CASTROL 20W50/55 GAL DRUM-QT 5.00 EA 3.25 2.27
BDM100-00018 5/16" FUEL LINE 2.00 EA 1.05 0.65
BDM100-00021 CHROME OIL FILTER 1.00 EA 12.00 8.50
BDM100-00117 1/4"VACM PLG,RUBRP/N150099014 1.00 EA 0.70 0.45
BDM100-00134 FUEL VALVE - FORWARD (REVISED) 1.00 EA 60.00 44.00
BDM100-00166 AIR CLEANER COVER & PLATE-CHR 1.00 EA 52.00 36.00
BDM100-00005 AIR CLEANER COVER & PLATE-CHR 1.00 EA 85.00 57.00
BDM110-00004 CHROME SIDE COVER WASHER(6099) 1.00 EA 0.50 0.40
BDM120-00044 DOMED DERBY COVER,ENGRVD,POLSH 1.00 EA 65.00 45.00
BDM130-00058 R DASH MOUNT TAB,03 MS 1.00 EA 3.92 2.74
BDM130-00059 ECCNTRC DSH SPCR-ZINC PLTD 1.00 EA 6.00 4.00
BDM130-00106 2004 49 STATES LABELS-S&S 1.00 EA 0.44 0.31
BDM130-00113 2004 PB GVWR DECAL 1.00 EA 1.27 0.89
BDM130-00139 .060 TWO PIECE TANK SHIM 1.00 EA 3.77 2.64
BDM130-00143 04 BX/PB FRNT FNDR MOUNT, POL 2.00 EA 20.74 14.50
BDM130-00251 LOWER GAS TANK ADAPTER PLATE 1.00 EA 15.80 11.05
BDM130-00292 AXLE BLOCK COVER KIT - 04PB/RB 1.00 EA 43.13 30.16
BDM130-00299 1/4" S/S BRAIDED HOSE 1.50 FT 3.30 2.30
BDM130-00306 1/4" CHROME HOSE FINISHER 2.00 EA 3.22 2.25
BDM130-00363 Flatsid gastnk mnting kit-chro 1.00 EA 48.00 31.00
BDM170-00115 04 PB/MS ANNUNCIATOR 1.00 EA 97.48 68.17
BDM180-00172 DOT 5 BRAKE FLUID LABEL 2.00 EA 0.60 0.40
BDM190-00006 EXHAUST CLAMPS 1.00 EA 15.00 12.50
BDM190-00007 EXHAUST GASKET 2.00 EA 3.20 2.25
BDM190-00013 2:1 EXHAUST SYSTEM, 04 RB/PB 1.00 EA 650.00 450.00
BDM200-00049 GRAPHICS PACKAGE - 3 DAY 1.00 EA 801.67 560.61
PART FOR GRAPHICS PRDCT STRCTR 1.00 EA 0.02 0.02
BDM200-00062 '04 PITBULL PAINT KIT 1.00 EA 1,992.66 1,393.47
BDM200-00004 03 MS ROUTERED DASH-2 5/8" SPD 1.00 EA 81.00 60.00
BDM200-00021 21" FAT FRONT FENDER, '04 PB 1.00 EA 127.00 89.00
BDM200-00024 LNDMRK GASCAP SET-CUST-CK VAL 1.00 EA 114.40 80.00
BDM200-00033 LH ELECTRICAL TRAY COVER 1.00 EA 109.40 76.50
BDM200-00034 RH ELECTRICAL TRAY COVER 1.00 EA 109.40 76.50
BDM200-00172 11" RIGID REAR FENDER 1.00 EA 155.58 108.80
BDM200-00069 Full Capacity Strtch-GasTnkSet 1.00 EA 495.00 300.00
BDM230-00065 2004 PITBULL SOLO SEAT 1.00 EA 265.00 175.00
BDM230-00076 1/4-20 RUBBER WELL NUT 6.00 EA 1.05 0.72
BDM240-00017 1/4-20 X 1 SC ALLEN 3.00 EA 0.75 0.65
BDM240-00018 1/4-20x1" FLAT SOCKET HD SCRW 3.00 EA 0.94 0.66
BDM240-00030 1/4-20 X 3/4 SC ALLEN 1.00 EA 0.92 0.65
BDM240-00051 5/16-18 X 5/8 SC ALLEN 4.00 EA 1.00 0.70
BDM240-00054 5/16-18 X 3/4 SC ALLEN 4.00 EA 1.00 0.70
BDM240-00133 8-32x3/4" CNTRSUNK SCR POL SS 3.00 EA 0.72 0.51
BDM240-00134 1/4" SCREW CLAMP (10/bx) 2.00 EA 0.49 0.35
BDM240-00291 1/4-20 X 7/8 BUTTON CAP 1.00 EA 0.81 0.57
BDM240-00330 1/4-20 x 1" HEX BOLT, ZINC 6.00 EA 0.07 0.05
BDM240-00353 1/4-20x1/2 Button Head-Blk Oxi 2.00 EA 0.16 0.11
BDM240-00355 1/4-20x1" BUTTON SOCKET BLK OXID 4.00 EA 0.10 0.07
BDM240-00371 1/4" FLAT WASHER, ZINC 6.00 EA 0.02 0.01
BDM240-00375 5/16 X 1 FENDER WASHER 4.00 EA 0.06 0.04
BDM240-00382 5/16" INTERNAL TOOTH LCKWSHR 4.00 EA 0.03 0.02
BDM240-00418 5/16-18 THIN HEX NYLOCK (50PK) 4.00 EA 0.36 0.25
BDM240-00428 1/4-20 U-NUT (50PK) 1.00 EA 0.43 0.30
BDM240-00441 NITRILE LOCK WASHER 1.00 EA 1.15 0.80
China sealed rear bearing: 6205-1-2RS (these are the one and only special order bearings from the original BDM source, according to the sales rep. He asked if they were for a Big Dog and I said yea.....told me BDM ordered a combo bearing and the only ones that produce them are Chinese.) SKF sealed front bearings: 6204-2RS National Metric front bearing seals: 28x47x7
These are what I got from BRC.
Maybe it's just me or i'm going blind, but I cant find the bearings and seals listed :bang:
FRAME ASSEMBLY
FRONT FORK INSTALL
HANDLEBAR INSTALL
BRAKES
WIRING
Wiring Bolt-On
WIRING PREASSEMBLY
WIRING PREASSEMBLY
I'll try this...Thanks
05 old dog
ps...pull front wheel and remove seal...if it is a tapered bearing it will fall out and you dont have to break down the hub assembly...if it is the 05 or newer style you will have to break down the hub assembly and press old out and press new in...
Its a pia press fit for sure. Just did my 04 Pit this winter.
