M-Unit Update
GDOG_PITBULL
So after reading and tracing and printing, etc. the unit is installed. Turn the key on and.......nothing........try and do the programming and ....nothing. No lights anywhere...ignition module, M-Unit.....nada :confused::confused:
Not sure if I missed something or what.....the ignition is the Ultima 53-642, not sure what else to list. Bad unit from the factory? No idea. Guess I will wait till Thors or someone finishes a wiring diagram.:cheers:
Thanks
G
GDOG_PITBULL
So I found a youtube video and it showed a bench set up with the unit and with the addition of one connection the unit powers up and turns the starter but no ignition. I am not getting any fire / power to the ignition. Can anyone tell me how the Ultima 53- 642 need to be wired in? I cannot seem to find where the orange # 13 wire from the key/switch needs to connect to and the Ultima color coding is not familiar to me. Not sure if the programming step are absolutely necessary or not either...the directions for this unit plain suck IMO!
PS - No lights on the Ignition in the Nosecone
Thanks
G
GDOG_PITBULL
Haaaa......the Dog Lives...Breathing fire with a growl that makes the old neighbors hate and the women :whoop:....well..you know the rest...:2thumbs:
G
GDOG_PITBULL
Need to do the "clean installation" now.....route the wires, etc. Going to get a couple terminal boards and try and make it nice and tight.
G
G
The sweet sound of VICTORY.
Let us know what the issue was after you get out for a ride. How did the blinker/break issue work out for you? You got the badlands unit, correct?
GDOG_PITBULL
I was not wired completely and have not worked the rear light yet. I have the 5 to 4 wire adapter to wire in.
G
GDOG_PITBULL
Ok, after a lot of hours and sweat...here is the project at 98% finished.
Will probably go with another widget to get the rear lights in order as I can do everything except brake lights. Everything else seems to work great!
WP was easier but the M-Unit appears from to be a much better choice out of the gate!...:cheers:
G
GDOG_PITBULL
I should really trim the red wires to length and it would look even better:cheers:
I want to ride it a while before I put the final seal on it:whoop:
G
GDOG_PITBULL
Rode all day yesterday with nothing but positive results. Bike now fires up 100 times easier than before:whoop: So glad that that piece of shit EHC is gone!
:2thumbs:
G
1BADK9
Limited Edition Member
Nice to hear that is at least one more option to the EHC replacement and GDOG trouble shooting will be a cinch if you have any problems I can tell you right now it's the "red" wire. :roll:
Looks good man yeah if you have the time and patients make us a schematic.
