Hello... i am trying to figure out the ignition circuit on a 2007 mastiff... i have the wiring diagram -- my questions are
1. the connector with red/green/black coming from the EHC to the thunderheart has a constant 8 volts with the switch ignition key either on or off.... is this normal ? seems odd
2. there is another red/green/black connector coming from the EHC going to the tranny speed sensor,, the red wire on that switches on and off with the key and has 13 volts... i was planning on grabbing that switched hot wire to power the ignition on the new ultima motor i am installing -- does that make sense ?
i may end up rewiring the whole thing but want to get this thing started and trying to figure out a "clean" way of wiring ....
thanks in advance
thanks in advance
