I have had a battery load test fine so I changed the starter. Same shit. It was the battery.Appreciate it. I did just have it fully charged but they had no idea what it should read. I'll have it checked again tomorrow to make sure it reads 12.8 and go from there. Thank you.
You could disconnect the green solenoid wire at the starter solenoid and use a 16ga jumper wire from the batt+ terminal to see if the starter kicks in when the bike is in NEUTRAL of course.Had the new battery checked at harley, battery was fine. No movement on the solenoid either when i push the start. Think i'm just going to have to break down and have someone come check it out. Appreciate all the feedback guys.
