Did the v-nose make it any easier? I don't have a v-nose on mine.6X10 V-Nose
Yeah chopper sits forward a bit. Should still work though.Did the v-nose make it any easier? I don't have a v-nose on mine.
Thanks for the picture..
Very true, happened to me with 6 animals on the trailer. it all depends on the value of the contents of the trailer. yours to decide, I personally wouldn't have any value in a single axle trailer.also, with two axles, if 1 tire blows, you still have 3 to keep you up and in control.
Slightly off subject, but did you put that floor down or did it come that way?I have a 6 x 12 Haulmark Low/RT and Have put 2 bikes in it staggered. I wanted a single axle so I didn't have to get it inspected in Pa. However I ordered it with brakes which took the GVW to 3500#but I still registered it under 3000#. I didn't want it coming around in an emergency stop.
I did the floor but the walls are finished on the R/T option.Slightly off subject, but did you put that floor down or did it come that way?
Thanks.
Cool, I sent you a PM.I did the floor but the walls are finished on the R/T option.
In the great old commonwealth of Va. if you have brakes, no matter the number of axles, you have to have them inspected.I have a 6 x 12 Haulmark Low/RT and Have put 2 bikes in it staggered. I wanted a single axle so I didn't have to get it inspected in Pa. However I ordered it with brakes which took the GVW to 3500#but I still registered it under 3000#. I didn't want it coming around in an emergency stop.
