I am not the most mechanical individual to grace the earth but I will try anything. Mechanic suspects push rod adjuster failure or tappet failure because the push rod is still under the arm and not above it as if it came loose during a high rev..... Is there a good way to check either of these? I will look at the push rod.
In spite of your past posts and in spite of your labeling my comments as "retarded" on my "park bench analogy" (don't ever do that to my face!) for lawsuit-crazy America, I am going to try to take the 'High Road' here and try to help.
I looked for your previous post on the front cylinder failure and couldn't readily find it (so please post a link).
My advice is to really look into the history of what has been done to this bike (motor) and by whom. This kind of problem is usually due to someone adjusting something wrongly.
If you can pinpoint an issue in maintenance or adjustments prior to this problem, maybe go for the fix instead of the blame (unless it is flagrant).
If you are not sure how to fix this, then ask for a referral to a reputable shop in your area.
I know that there are numerous articles on this site about adjusting push rods and on S&S care and the net is full of helpful info on evo type motors.
I have both the S&S manuals for their motors and the K-9 service manuals if you need help.
I hope you can get up and running and enjoy your Big Dog as many on here have in the past and continue to do so!
Trying to sue a 'no-longer-in-business company') is in my opinion NOT your answer.
This is a sincere response and I hope we on this site can help.
Shovelcowboy
