bigdoghogz
Hey guys and gals.....I have an 04 Big Dog Chopper and I've had some electrical issues lately with it dying during a ride. this is what Ive done thus far...
Replaced the coil
Replaced the Ignition switch
Replaced the Thunder Heart Module
Replaced the Battery
checked all ground connections----looks good
Unplugged the the speedometer because it looks like its getting burned inside the unit and tach was acting weird!
Installed a new Ignition Sensor which was what was causing the problem all along. or was it? Ill explain.....
Once I installed the the HD ignition sensor and hooked everything back up including the speedometer It ran Fantastic. For two days. went out to start it at work and the new sensor went bad. went to HD and got another sensor and installed it. unplugged the speedometer because I think it has a short or the EHC has a short or both. I also Bypassed the EHC power to the Thunder Heart Ignition Module and hooked up directly to battery with a fusable link. Bike is again running. My Question is...could a short in the EHC and Or the Speedometer be causing the problem? I'm hoping to avoid going to through yet another ignition sensor. Any wisdom you can add to this issue would be greatly appreciated. On another note...I vote that we tar and feather the dumb dumb that designed the electrical system for these bikes! im just sayin lol.
Kirk
Replaced the coil
Kirk
