you beat me to it, agree.Check petcock screen to make sure it is not clogged.
Check for tank liner deterioration that my have clogged system.
Don't know much about this EFI dogs, but is there a fuse for the injectors, I would check that out being that the pump is working and you have spark. It could also be the crank sensor. Also check to see that the TPS is working as well that it didn't come undone. Hope that helps. Do a search maybe someone with EFI had the some issue before and was able to track it down.Riding home today when engine stopped. Unable to restart. Battery and fuel fine. Stater turns over easily. Has spark. Can hear fuel pump turn on but no fuel getting to engine? 09 Wolf with 13,000 miles. Closest dealer 3.5 hours away. Any suggestions? Thanks Scott
Just got back from S & S. Pulled cam cover. Belt shredded. S and S going to replace cam belt, cam plate, and update to 569 cams for free. They are one of the most dependable and service friendly companies I have ever dealt with. Should have the Wolf back early next week. Scott
I'm assuming you have EFI. The controller is S&S VFI...Any S&S dealer can get it for ya. Yours may be unlocked. I think someone else had a newer bike and the controller was not locked.What programable ECU? Who makes it and where do you get one? Thanks Scott
