Knuckles
07 K9 original battery lasted 3 yearsWell i went out to start the scoot the other day...hit the start button and heard the starter grunting as it was struggling to get through the compression stroke
(no compression releases) then "click" click" from the starter.
I thought to myself "loose connection" removed the seat and took a looksy .... crap!! ground connection must of been loose because it melted the lead negative post down the side of the battery and there my cable stood in mid air as if it was exposed to a nuclear blast....I love my Braille Battery:2thumbs:
Well I call to order another Braille from our local distributor and he tells me Theres something better i'm thinking shut the hell up ... nothing better than a Braille...:loony::loony:
Well no bull shit .... this is one bad ass battery...made in the USA by the same company as Braille and it kicks ass
(bought it) "465 CCA" more power than the Braille and same dimensions and one model is "500CCA" let me cut out all the story telling here it is ...oh yeah 2 yr warranty
Here is the specs: TOMIOKA $157.00
PRODUCT DESCRIPTION
Just the right size and weight, TR-B1500 offers little weight addition and significant power increase than TR-B1100. It’s small enough for 4-cylinder vehicle without the added weight, in other words just right. Perfect for racing and daily driving vehicles.TR Battery utilizes Absorbed Glass Mat (AGM) technology which increases specific power and ride quality and environmental safety. The design allows the battery to be mounted in a variety of positions and to accept automotive terminals vertically and horizontally. Included with each TR Battery are quality brass SAE terminals, designed to distribute the electrical load battery for high amperage, high stress use of racing and audio applications.
Features:
- Leak-Proof Pressurized System design is engineered for safety and long life.
- Sealed, Valve-Regulated, Maintenance-Free Design eliminates damage from acid spills and corrosion, environmentally safe. 100% recyclable.
- Heat-Sealed cover eliminates electrolyte leakage and improves reliability.
- Molded Top & Side Connection terminal design provides ease of installation, increased strength and durability.
- Stainless Steel terminal threads to keep the terminals intact under vibration
- Low discharge rate during storage
- 2 Years Warranty
Specifications
Model Number TR-B1500
Length 6.8 inches / 176mm
Width 3.5 inches / 89mm
Height 6.1 inches / 158mm
Weight 15 lbs / 6.8 Kg
Voltage 12V
Full Charged 13.8V
CCA 465Amp
Capacity 17.5 Amp/Hour @ 10 AH Rating
Replaced with a harley battery 2 years ago....which is starting to die.
Bought this Tomioka from AdvanceSpeedShop - Discount Performance Auto Parts | Low Pricing | Est. 2007 for $176 including shipping to Colorado. Put it on the charger last night. Can't wait to see how it cranks!!
now what
