outdoorsman26
I also used the longer bolts in the heads but I took a stainless washer an cut it down so it would just fit in those holes, I also made the camel toe bolt 5/16, red loctite on it all! they have'nt moved at all!!
Your reading too much into it. Look in your service manual section 2 the top bolt S/B a 1/2"-20 x 1 3/4" not a 5/8"-20 x 1 3/4"where are you guys finding 5/8-20's?? Nobody locally has that size! even online i can only find 3/8-16 or 1/4-20 is the closest...
can anything be just plain and simple...jeezzz
Thanks Nuke,It should be 1/2 inch 20 tpi.
I am so sorry, I gave you the upper mounting bolt from the service manual. I just measured my coil cover chrome bolt and it was 3/8"-16 and an inch long as described in the service manual. I also measured the depth and 1.5 inch depth with a washer will work. I think I will order some longer ones myself.Thanks Nuke,
The webpage is giving me these thre options... which one should I order?
Your help is very much appreciated.
Coarse (standard) thread
1/4"-20
5/16"-18
3/8"-16
Socket cap (smooth), Chrome plated grade 8 steel - Bolt Depot
Thanks Haw,I am so sorry, I gave you the upper mounting bolt from the service manual. I just measured my coil cover chrome bolt and it was 3/8"-16 and an inch long as described in the service manual. I also measured the depth and 1.5 inch depth with a washer will work. I think I will order some longer ones myself.
That picture bothers me because it doesn't say or show threads the entire length. I just went to my local ACE Hardware store and picked up 6 Socket Cap smooth 3/8"-16 1-1/2 inches long as shown below with lock washers. I'll let you know how they fit once I get a chance to remove my ignition cover. I need to replace the ignition switch connector under the cover with a DTM plug.Thanks Haw,
so.... this ones Socket cap (smooth), Chrome plated grade 8 steel, 3/8"-16 x 1-1/2" - Bolt Depot are this ones the correct ones?
Cheers
rgr that, I will wait for your feedback before ordering (I´d hate to order the wrong ones :bangThat picture bothers me because it doesn't say or show threads the entire length. I just went to my local ACE Hardware store and picked up 6 Socket Cap smooth 3/8"-16 1-1/2 inches long as shown below with lock washers. I'll let you know how they fit once I get a chance to remove my ignition cover. I need to replace the ignition switch connector under the cover with a DTM plug.
Huw,That picture bothers me because it doesn't say or show threads the entire length. I just went to my local ACE Hardware store and picked up 6 Socket Cap smooth 3/8"-16 1-1/2 inches long as shown below with lock washers. I'll let you know how they fit once I get a chance to remove my ignition cover. I need to replace the ignition switch connector under the cover with a DTM plug.
Update: I put a 1-1/2 in the front and back like Gas Man did above except I used a chrome lock washer.
