This thread is pretty much played out. I have one more section and those are the compensator sensors. This here is more the base timing, the backup, the flash and with a flash, flash means, toggle the hard settings without spitting a code.The rest, not so much.
So, that tuning ability does not clear up any AFR trimming. It still means, you need a pig to tune after you set the hard or the rpm limiter settings. Things like that.
I would think this is a troubleshooting guide to that hard setting and a piggy still needed. All I am doing is exposing the FI functions. Those basics are how you catch spark loss and phantom moves not related to the main sensor in question is the other thread installment.
I would think, I am still relating to the tech part of troubleshooting no matter how you look at it. The 3rd installment says there is not much left in the loop. Minimum basics stated here and you are on your own.
You will still have computer driveability/tuning problems. FI is filled with variables now. Much more than a carb/spring advancer/set of points kind of ignition system. This relates to diagnostics. It just has to sink in is the basic concept of FI. Some are seeing how it walks. At least, they see something in the abstract making sense.
FI only works one way, no? Cam timing is assembled one way or it's a tooth off. So, is one way that engine is assembled? You bet. And plenty of troubles galore there too.
