Hi guys, The weather up here in Michigan is awesome right now BUT I can't get my dog to fire up...
2000 Husky
Only had it 1 1/2 years and it was hard to fire up last spring also but it's really being a bitch this spring and doesn't make sense.
Battery is fine, tested turns it over no problem always on a tender.
Just to make sure I drained fuel tank, replaced fuel filter and line, new fuel and I can see the main jet in the carb working.
When it turns over it just doesn't want to ignite and fire up. If I spray a little starter fluid in the carb it fires up for 1-2 seconds and then dies out, so I know I have spark and compression. It just doesn't ignite the fuel...
The carb was fine last fall but could it be something in that? I checked the adjustment screws to make sure they were ok.
Am I overlooking something simple. My 69 Sportster is a hard starter in the spring also but the BigDog should have fired up by now...scratching my head here and want to get on the road this weekend bad!!
Any thoughts appreciated, thanks
2000 Husky
