BigD07
I am having issues with a hesitation when cracking the throttle. After checking the accelerator pump out, it is barely pushing the pump rod down so there is no way to adjust it to get more fuel squirt. After comparing the XXX to the stock carb it takes more pressure for the XXX to do the same amount of travel. I was wondering if anyone has had this issue or if you can get a stiffer spring to help it out?
