Not sure if it was mentioned, but before adjusting any of the pushrods, collapse all 4 pushrods and let the lifters completely expand. Otherwise, zero lash may be with a lifter that has not fully adjusted prior to finding zero lash and that would not be a proper adjustment. Follow Little Boo's procedure. Pull plugs, collapse all 4 pushrods, wait 15 minutes, then turn rear wheel until a lifter is at it highest point and adjust the opposite cylinder pushrod of the same valve (intake or exhaust) to 4 turns. And also like mentioned above, tighten the hell out of the lock nut. Wait 15 minutes and you should be able to spin the pushrod you just adjusted by hand. Then turn the wheel till another rod is in its highest position and adjust the opposite cylinder of that same valve. Follow this until all four pushrods are adjusted. Be sure to wait 15 minutes on that last pushrod before turning the wheel again to give that lifter time to adjust or you could cause damage.
