1goodsinner
My gf first noticed it from the p-pad position,but there is a chirping type of noise coming from the right side possibly near the belt/tranny area!Is this a typical noise,and if not ...WHAT COULD IT POSSIBLY BE?
This has my voteCheck upper motor mount bolt.
I agreeThis has my vote
What he said! After correcting the tension if squeak is still there take some WD40 and spray on the belt, if squeak goes away then belt and pulleys are worn out. If this turn out to be the case there are a few paths you can take. Replace them with new BDM sprockets and belt or send your rear sprocket to SuperMax (which is what I did) or live with the squeak.:lol: SuperMax is a more permant fix.:2thumbs:Brake pads, Wheel bearings or a Belt drive squeak on the rear rotor more than likely.
Check the belt tension with two people on the bike and make sure it's not too tight. I feel the BDM spec is too tight and contributes to premature rear wheel bearing failure. We run our "07" Bulldogs at about 1" to 1 1/4" up/down overall movement.
The belt should track near the center of the pulley but could be set to one side. As long as you can see a gap between the belt and the rotor sidewall it should be ok.
The belt is worn and/or streached. The geometry and pitch of the belt lobes no longer matches the rotor and then the belt slips into the lobes instead of aligning with the lobes causing a squeak.
Try some silicone spray on the belt to see if the squeak goes away.
Check the front and rear pulleys for stone or debris damage, wear, dirt etc..
Search the form for "belt squeak" You should find more information.
Also a candle will do the same job (a little less messy if you want to carry it with you). We would use that as a quick/temp fix on fan belts out in the field.Most likely belt chirp...a well known issue. Take a bar of soap to the side edge of the belt (not the teeth) and see if it goes away for a while. If so you may need to align the rear wheel.
G
