BigDogBro1
Made in the USA
This will help.....you won't need to remove the tank to check the wires in the speedo housing, unless you want to check the connections under the tank and get some extra cable length to play with.
http://www.bigdogbiker.com/forums/how/451-how-remove-install-swap-your-speedo.html
