moesterman
I am in the process of installing the BDM harness w/PDM to eliminate the EHC. When I pulled the fuel tank I noticed two wires that were rubbing and almost completely severed. Both wires are to the compression releases (Green and Black). I decided to cut the shield back and splice the wire when I discovered one of them was rubbed through the shield for several inches (6-7) exposing the conductor. Now I do not believe splicing is an option. The damaged wire are the legs fron the head to the backbone so they are not replaced with the new harness. Next I thought I would replace the damaged legs but not sure if I can order for BDM but will call. Secondly, I have no clue as to how they connect to the head/release. I am open for all ideas/suggestions/options!
