"Ground" connections on an 08 Mastiff
Cshores
Does anyone have pictures of where the ground connections are located on an 08 Mastiff so I can insure they are properly connected?
I posted on another thread that I am doing my PCM wiring check list and it appears I have found a semi loose connection with two of the wires that converge into a black connector that is attached to a "bronze" bolt underneath the fuel tank. Driving me nuts because I can't figure out how to take it off the bolt and see why it is loose. Not sure what it is.
Any advice? Thanks in Advance.
Cason
erldawg
Cason
How about a picture ?
Cshores
This is the picture of the connection under the where two wires come into a single "housing" connecter and connect to a bronze bolt. This is what was somewhat loose but there was no way to tighten. I just threw a bunch of di-electric grease on it.
Any thoughts on how to make that connection more stable?
