Frundsberg
I just had my '08 K-9 Ehc system replaced with the Wires Plus system, along with the ign. switch and Efi kit. I keep my K-9 and Harley on battery tenders. The tender on the K-9 keeps charging and went into stand-by mode only twice in the three weeks since the Wires Plus install which was performed by a Victory/Big Dog mechanic who has experience with replacing the stock Ehc with the Wires Plus system. I switched tenders on the two bikes and got the same results. The company who I got the tenders from three years ago advised that the K-9 wiring is the culprit causing a constant battery drain. The Big Dog mechanic cited his hard wiring of the system and advised that since I have no electrical add-ons such as clocks, etc. there should be no drain upon the battery. I will be taking the K-9 back to him on Jan. 3rd for his inspection. I am curious to know if any of you have had a similar incident after a Wires Plus equipment install? I had a new battery installed at the same time as the WP kits and it checked out good. Thanks, Frundsberg.
:2thumbs:
